silencethevoice Posted October 5, 2006 Report Share Posted October 5, 2006 Hello all.. I'm in the midst of installing a Trinity 2 to 1 and a set of V-force reeds.. The trinity intake has o-ring seals, but the v-force comes with a set of gaskets to use... Which should I use, or should I use both ? What are you guys runnin'? Just tryin' to avoid any problems down the line.. Thanks in advance, Ryan Quote Link to comment Share on other sites More sharing options...
Dmcbanshee Posted October 5, 2006 Report Share Posted October 5, 2006 I have the same setup and I use both and I never had problem... Quote Link to comment Share on other sites More sharing options...
sredish Posted October 5, 2006 Report Share Posted October 5, 2006 yes, continue to use the paper gaskets or you'll have leaks. Quote Link to comment Share on other sites More sharing options...
silencethevoice Posted October 5, 2006 Author Report Share Posted October 5, 2006 yes, continue to use the paper gaskets or you'll have leaks. Thanks guys! Just thought I'd check.. Gotta love the HQ.. :smile: Quote Link to comment Share on other sites More sharing options...
differentstrokes Posted October 7, 2006 Report Share Posted October 7, 2006 I use the paper gaskets too, I had the same question so I called Trinity and they said to stick with them instead of o-rings. Quote Link to comment Share on other sites More sharing options...
