Rear Sprocket Hub Problems
I noticed just the other day after swapping my Sand Gecko's back over to my Klaw XCR's that my rear sprocket and hub have a little bit of play in them. I checked the axle lock nut which is still stock and it fixed the wobble for awhile and now the hub is loose again. Is there a bearing or spacer that needs to be replaced? If so where could I get replacement parts for cheap?
The axle nuts tend to work loose
Anytime I work on rear axle (and on all of my own quads) I clean the nuts and axle with carb cleaner. Then take a Sharpie (permanent black marker) and draw a straight line across both nuts and on the axle. The mark will usualy last through quite a few washings. As long as the mark lasts, you can tell at a glance if anything has moved or started to loosen.
