cam2 Posted October 4, 2006 Report Share Posted October 4, 2006 how many of you guys ported or had your case match ported to the jugs? the transfer ports on the jugs are larger than on the case. does it make much of a difference either way? it seems that the transfers are bigger than stock for a reason. but is it worth the risk of taking off too much material or not having the porting even on each side? Quote Link to comment Share on other sites More sharing options...
addicted Posted October 4, 2006 Report Share Posted October 4, 2006 how many of you guys ported or had your case match ported to the jugs? the transfer ports on the jugs are larger than on the case. does it make much of a difference either way? it seems that the transfers are bigger than stock for a reason. but is it worth the risk of taking off too much material or not having the porting even on each side? It makes alittle bit of diff. Didm't seem to be much. I've been told that it makes it a little smoother. I didn't really notice any change there. Quote Link to comment Share on other sites More sharing options...
Ducman Posted October 4, 2006 Report Share Posted October 4, 2006 I'm no expert but I think you mainly just want to port match to the gasket. You dont need to blend it very far into the case. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted October 4, 2006 Report Share Posted October 4, 2006 Here's mine... Quote Link to comment Share on other sites More sharing options...
lowriderb Posted October 4, 2006 Report Share Posted October 4, 2006 matching them makes use of the whole flow area, which should net you a few ponies... every little bit adds up to alot.. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted October 4, 2006 Report Share Posted October 4, 2006 cam2 you got your shee apart? :: are you going to ocala 20-22? :biggrin: Quote Link to comment Share on other sites More sharing options...
cam2 Posted October 5, 2006 Author Report Share Posted October 5, 2006 cam2 you got your shee apart? :: are you going to ocala 20-22? :biggrin: yep, putting a cheetah kit together. i wouldn't be able to make it anyway, that's opening weekend of georgia's firearm deer season. Jared, did you do that yourself? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted October 5, 2006 Report Share Posted October 5, 2006 yep, putting a cheetah kit together. i wouldn't be able to make it anyway, that's opening weekend of georgia's firearm deer season. Jared, did you do that yourself? Yep. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 5, 2006 Report Share Posted October 5, 2006 It's probably worth 1 to 3 ponies at best... Quote Link to comment Share on other sites More sharing options...
