Raptor-Idle Problem
Redlined
Does it backfire when you ride it and are decelerating? Double check the clamps on the intake. What pilot jets are in the carbs? Sounds like a lean conditions that's being caused by an air leak, low float level, miss-adjusted air fuel screws or partially pluged pilots. How many turns out on the air fuel screws?
Does not back fire. (it did when we first started having this problem, but it doesn't now) Screws are set to factory. (One is 3.5 out and the other is 1.5 out).Intake clamps have been checked and tightened. The pilots are, whatever comes with the LTE pipe kit (Note: we had this problem even before the pipe was installed). Floats have been adjusted and checked.
We have been through the carbs many times and we are wondering if it could be associated to the valves???, or some thing else. We agree that it seems to be an air leak of some kind, maybe. Are these carbs very sensitive or what? We want to eliminate other possibilities before purchasing new carbs, as the brilliant factory technicians suggest...
Set the mixture screws at 3.5 L and 3 turns R. 1.5 is just too lean. I cant see the valves being that far off but it doesn't take that long to double check the settings. When you have it running, spray carb cleaner around the intake boots. One might have a slight crack causing a vaccum leak and the cleaner will cause it to slow down/stall if there is.
