bigdaddy69 Posted September 27, 2006 Report Share Posted September 27, 2006 yesterday i did my first rejet ever im new to the banshee world i have pro circuit pipes stock filter with no snorkel and a milled head .030 riding at 3400 ft temps 70's to 100...i went from stock 200 main to 250's put carbs back in a fired her up she started right up but bogs at the slightest touch of throttle its really bad when motor is cold when it gets hot its still there not as bad but still having to feather the throttle.....today i warmed her up on old plugs swaped out plugs pulled choke out halfway shee almost died so i turn air screws out this did next to nothing i spent over 2 hours tinkering with it...finally got frustrated and put her back in the garage...any suggestions would b great i have no idea what to try next Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 27, 2006 Report Share Posted September 27, 2006 I think you're still rich. That would explain easy starting...but a little boggy after it's warm. Especially if it got even worse when you pulled the choke. You're fine on the mains for now...maybe rich, but definately safe. Try turning your air screws all the way in, lightly seated, and turn each one 1.0 turns out. See if that helps. Do one setting at a time. Once you get your off idle to 1/8 throttle better, move to the needle. It's probably in the middle clip (stock). Try leaning it out one clip ...or one clip toward the blunt end. If all this jetting doesn't seem to make a difference at all....you might not have a properly sealed head.... With an air leak, you can try every jet setting in the world...and it won't hardly make any difference.... Quote Link to comment Share on other sites More sharing options...
bigdaddy69 Posted September 27, 2006 Author Report Share Posted September 27, 2006 I think you're still rich. That would explain easy starting...but a little boggy after it's warm. Especially if it got even worse when you pulled the choke. You're fine on the mains for now...maybe rich, but definately safe. Try turning your air screws all the way in, lightly seated, and turn each one 1.0 turns out. See if that helps. Do one setting at a time. Once you get your off idle to 1/8 throttle better, move to the needle. It's probably in the middle clip (stock). Try leaning it out one clip ...or one clip toward the blunt end. If all this jetting doesn't seem to make a difference at all....you might not have a properly sealed head.... With an air leak, you can try every jet setting in the world...and it won't hardly make any difference.... its got to be the jetting because i ran it with the new head before i rejetted and it ran fine no bogging at all Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 27, 2006 Report Share Posted September 27, 2006 I'd agree then. Did you remove and/or take off the carbs when you put the milled head on? If so...either you made a mistake putting the carbs back together, or the jetting is way off. And to be honest....it might not run perfect, but it should be darned close with that jetting... Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 27, 2006 Report Share Posted September 27, 2006 Well...whaddya know.... He PM'd me that he unplugged the TORs...and it's much better. Still has to fine tune it I'm sure.. Here is the whole TORS removal kit, including new Carb Caps, Throttle Cable, drill, tap and Idle screws for the carbs. http://www.magicracing.com/TORS-Eliminatio..._p_310-731.html Quote Link to comment Share on other sites More sharing options...
SkunkWerX Posted September 27, 2006 Report Share Posted September 27, 2006 The TORS unit is so smart it detected the new jets, and shut him down! I'll bet TORS has made the Yamaha ATV shop mechanics a lot of $$$$ since it's inception. Glad he found it fairly easily, score one for the home team! Quote Link to comment Share on other sites More sharing options...
