backwards banshee
bigwill
LMAO.... Ok this is great a banshee starting and going backwards....LMAO...the funny thing here is that my banshee did the same thing and noone in town would belive me....BIGWILL the reason a banshee run backwards is ONLY from back fire.....the motor has to be back fireing bad when you kick it, the crank can turn backwards and fire, which makes the the bike start but you have reverse... now there are few things that will do this MAJOR reason is the flywheel not on correct.. Buy a new key for 4 bucks, and make sure it lines with the key way in the fly wheel...Im willing to bet this is the problem...there are 2 others that can cause it to happen every now and then...But the flywheel missalligned is the problem with yours...
