shaved head
Bill
Bill....you should be ok with 50/50....+4 and a .025 head.
I wouldn't go too much more...unless you're prepared to have the crank welded for insurance.
(Which, it should get welded, anyways....they're just pressed from the factory...)
Even so...check the compression to be sure...each engine is different!!
Heck, Bill....
Since you're welding the crank, go .020. See how you like it...and check the compression.
You might even be able to run pump gas on that, depending on the compression.
If you want to go more...take it off, get another .010 taken off...
It's only a little for the machine work, gasket, time and a little coolant.
If you didn't want to do it all over again, I'd say .025 and 50/50 SHOULD be pretty safe...but, always check to be sure!!
