help me, lost with jet
Eddie
Solid advice above here from Bill.
Stock Mains are 200. Some dealers will install 190 or 210 depending on temp and elevation of their dealership...
Eddie, what elevation are you riding at, and what temps are you riding in.
Normally...if all you did was put a K&N in and remove the snorkel, I'd say go one to two richer on the main, and .5 turns in on the air screw. Needle should be fine in the middle clip....(stock)
My elevation is 3800ft and my current temp is ranging around 5 - 18 degree celsius
Eddie...how does it run with the 190 in there?
Because of your elevation, stock bike with the exception of a removed snorkel and K&N, I'd say a 200 to 210 would be about right for you.
the idiot i bought it off of had the needle clip set to fourth, and a 190 main, and it doesnt run like a shee should, but thanks for the help just needed to know what i should set the main and the air screw
