getting out of the hole
bigbdog
if u race on the street and you get a good spin in 1st, you should never get behind him but on the dirt you'll spin the tires like crazy. out of the hole, not even porting will help u unless you are on pavement. 100hp + no traction= slow holeshot. 50hp + no traction = slow holeshot. this is given you are on the dirt. and i am only refering to 1st-3rd gear in the dirt. the only cure is move to the street....then eat him up.
pilot ^ is 100 % right... Tons of Hp and no traction sounds like me. I never hook up and end up spinning till 4th gear. i need some real tires to get my 10 mill to actually hook up... Overall i think you need a port job to gain real hp out of any banshee . I cant express enough what a Aggresive port job can do to a banshee. Try it out for yourself !
I recently put on t-5's, v-force 3 reeds, and a boost bottle. However, my friends 450 is still kicking my ass off the line. What is the best/cheapest way to take care of that problem? I was told port and polish. Then others tell me cool head with 20cc domes. What do you think?
If the boost bottle did not take care of the problem, nothing will, it has to be the best and most HP gain little gudget and retard as put out...
Anyways, port and polish is allways a great MOD, and very workable aroud the bike, coolhead may be a low end gain but nothing hugh are to feel a difference, port and polish is the first step...
Edited by Banshee4Drag
20cc domes will give you more low end but it wont help your holeshot. It's definetly a tire spin issue like everyone said. Try starting in second, if you get the hang of it you might do better. If you do go with the 20cc domes check your altitude first. At sea level 20cc wil give you 169psi compression. This is borderline for running race fuel. I run them and I'm at sea level so it works fine for me with pump gas.
I have a Dune port and am running 13/41 gearing with 21 10 10 paddles. On the sand I have never been left at the line by any thumper (launching in 2nd gear).
I tried 300ft dirt drag racing with the same setup and it bogged down real bad at the start. No wheel spin! It's all about the setup up!!!! best time was 6.007 with a .890 reaction time. Nothing like beeing a sleep at the switch :banghead: Going to give it one more try in Oct. ( just for fun & practice) then wait until the drag bike's finshed for next year!
  • 1 month later...
i hear the bottle is not a good thing. i beat the yfz 450 with my mods, was going out this morn to race a 450r hopped up, but it was too damn cold out. take a look at my mods.by the way with the mods i have done,i run the stock carbs at sea level with 320 main jets.
