plug chop questions
jesse1004
I recently got some engine work done so I did a plug chop to see how close I still was. Before the engine work I had 260 mains, 25 pilots, and needle on middle clip. I Did the chop and plugs seem to be almost grey and not brown and also instead of 2mm it is more like 3 or 4mm. Plus one of my plugs is alot darker than the other. I got a midrange port, bored .25 over and k&n pods. Do you think one main will be enough and also where do you think I should start in order to get the two plugs the same?
Edited by jesse1004
