Need a starting point
blacknred03
I am waiting for my jugs to come back and I just finished my TORS kit and snce I have the carbs out I guess I can throw in something close. Here are my mods:
Stock stroke
FAST dune/play port
FMF fattys, I know I know...
Stock carbs
NOS head
V-3s
+4 timing
running airbox with no snorkel and a K&N
Houston Texas, sea level
O.K go
Don't "I know, I know" IMO, Fatties are one of the best pipes you can buy for a stock bore/stroke banshee. killer bottom end and midrange with a top end that will hang with most std pipes. way smoother than Toomeys and I'll bet top end wise, they're pretty close, plus, they work even better on ported or modded banshees. I'd even run them on a +4 for an all-around type riding environment.
Anyways. Porting is a crazy variable. You could be at 380 or 340 depending on how the portwork was done, quality, style, etc. I'd start with 350's and do a plug chop. 27.5 pilot ought to work and the stock needle in the 4th clip. From there, you may have to go up or down, not really sure, depends on the port.
Above all, if the portwork is at all decent, you'll have a killer running bike. The fatties with good play porting will work well. Only thing I'd add is a single carb setup. That'll add more low end, smoother midrange and more of it along with better top. ;) Not too mention, easier jetting, tuning and a cleaner look.
Edited by sredish
