Anyone ever used a dyna 300cdi box?
oneslowbanshee
I have a dyna CDI on mine. I bought one with wiring plugs to fit my year ignition (96)...
If you're going to buy one from a different year than what you own...get out the clymers to match up the wiring....
To be honest, unless you have a dyno nearby and a laptop, cable and software to program the dyna, it's not worth the extra cost over a stocker CDI you can get new from Ricky Stator @ 125.00.
I plan on getting to a dyno one of these days...or just sending mine out to get reprogrammed...
I"m told Andy @ Grand River Racing has a very good program for them....
The whole purpose of this box is to allow clutchless upshifts by iterrupting your ignition...
You already have a cut tranny...which allows this...
Am I missing something?
The only benefit I see from this (maybe I'm reading this wrong...) is that it'll interrupt the ignition for clutchless upshifts, which...your override already does.
Why would you need anything for off the line? What am I missing??
:shrug:
My intent is to set it at lets say 7000 rpm "It is varable so not sure what to set it at will have to mess with it" To kick in and use a clutch lever with a switch in it to kick it in. Once I am off the line I dont need the clutch and the box will no work unless the clutch is pulled, that way I can hold the throttle wide open and not let the motor just be screamin wide open on the line. with one set rpm off the line it may help my 60ft. I am running 16 41 gearing now and I set the paddles on fire, may need to also go to more paddles but will see if the box helps
