Serious Answers only PLZ
DirtyFitz
Well I have Toomey T6's w/ K&N Filter w/ all the recommended settings beside 280's (I put 270's in after head). I went to Dumont Thanksgiving weekend 2005 and I was running rich so I decided to try 270's and I got them in and put gas in (32:1 is my ratio) and ran it up my street 3-4 times and my floats out of no-where have decided to stick but right before my float issue it ran okay (or just let all of my gas out of the overflow tubes). Before the float issue I got a good 4 rides and and the bike felt fine just a tad bit on the hot side so I figured I was a little lean. Im going to a local stealership in the next 2 weeks to pick up some 275's and try them. All my settings should be Toomey recommendations (270 Main Jets, 25 Pilots, 1.5 turns out on airscrew, 4th groove on needle.) I havent gotten the idle set and cant start the bike without pull starting it. I know the floats need to be at 21mm and I thank my Clymers manual for that but what do I need to do exactly to get my jetting correct and get my idle set. Ive read much up on here over the past year and I dont want to waste $100 on some fool to get my jetting done when I can do it myself with a little help from you guys.
If you need any more info let me know.
When you install the the richer pilot (27.5 air screw 1 to 1.5 tunrs out) that will make it easy to start, you also need to run a 310 main with a K&N filter/ air box lid off. 270 is way to lean. I used to run a 290 with a foam filter/lid off and FMF's.
