RHINO B Posted September 12, 2006 Report Share Posted September 12, 2006 WHAT TYPE OF STOCK CARB SET UP DO I NEED FOR MY BANSHEE FOR PERFORMANCE...IS IT DYNO JETS??? WHAT DO I NEED FELLAS??? Quote Link to comment Share on other sites More sharing options...
ranshee Posted September 12, 2006 Report Share Posted September 12, 2006 Your missin alot of info here. Pipes? Filter? Milled head? What are you asking? Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 12, 2006 Report Share Posted September 12, 2006 :baseball_mitt: WHAT TYPE OF STOCK CARB SET UP DO I NEED FOR MY BANSHEE FOR PERFORMANCE...IS IT DYNO JETS??? WHAT DO I NEED FELLAS??? I think you're a bit confused about jetting. You need jets for a Mikuni VM carburetor. Dynojet is a brand of jet kit that gives you a small selection of jets in a fancy package. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 12, 2006 Report Share Posted September 12, 2006 :baseball_mitt: I think you're a bit confused about jetting. You need jets for a Mikuni VM carburetor. Dynojet is a brand of jet kit that gives you a small selection of jets in a fancy package. Which is usually a waste of money, I might add... I'd rather buy the jets I need...rather than get what they "guesstimate" I need. And...as said. What are all your mods, riding temps and riding altitude... Quote Link to comment Share on other sites More sharing options...
sredish Posted September 13, 2006 Report Share Posted September 13, 2006 jet kits are bullshit and never give you what you actually need. dynojet needles suck. they're simply blaster needles repackaged as "dynojet" performance needles. keep the stock needles in the stock carbs and you'll be golden. then figure out what main jets you'll likely need to try and order them individually from magicracing.com or carbparts.com. that'll be cheaper than a jet kit and will accomplish the same thing or more. also include a set of 27.5 pilots and 30 pilots to play with. Quote Link to comment Share on other sites More sharing options...
Ducman Posted September 14, 2006 Report Share Posted September 14, 2006 You cant simply "jet" for more performance. If you install mods that increase the engines air flow potential like pipes, K&N filter, remove the air box lid, ported cylinders ect, then you can install larger jets so your carbs can flow more fuel to go with the added air flow that resulted from the mods. More air + more fuel = more power If you just add more fuel and not more air = less power + fouled plugs + bogs and runs crappy Quote Link to comment Share on other sites More sharing options...
