aczar Posted September 19, 2006 Report Share Posted September 19, 2006 I also have tried the plastic type tubing they sell at lowes,home depot etc. And once it heats up the hose gets soft and starts to sag, and mine just blew the whole hose out where it had started to bend and I had to get towed home by a Suzuki :: . If you look at the tag or packageing on this stuff(clear and braided) it says its only good for like 110F and like 5psi. And the Shee radiator cap dosent release pressure unitl 13.8-18.1 psi. I checke at some local industrial suppy stores and you can purchase a clear high temp hose like you see in all the kits but I could only find it in 1000 foot rolls and a 5 bucks a foot its not worth it. IMO Quote Link to comment Share on other sites More sharing options...
racer Posted October 13, 2006 Report Share Posted October 13, 2006 (edited) that temp rating means it has to hold the pressure rating at that temp. so, heat isnt really a factor here since the temp isnt high enough to melt it, and the pressure isnt high enough to burst it. EDIT: i just saw your post, and i remember some triple digit pressures on the hose i used. maybe you shouldnt be using the plastic, but instead the PVC. EDIT 2.0 the pressure rating on .750" ID PVC braided hose is 150psi. Edited October 13, 2006 by gimmeabeer Quote Link to comment Share on other sites More sharing options...
GEEZR Posted October 16, 2006 Author Report Share Posted October 16, 2006 Just got back from my 1st ride with the clear braided PVC hose. No problems (yet). They do tend to get soft and very plyable. I will keep my eye on them tho. I still have the original hoses in my truck just for back up. These clear things look Ssswweeet !!! Quote Link to comment Share on other sites More sharing options...
BANSHEEPRO Posted November 14, 2006 Report Share Posted November 14, 2006 Just got back from my 1st ride with the clear braided PVC hose. No problems (yet). They do tend to get soft and very plyable. I will keep my eye on them tho. I still have the original hoses in my truck just for back up. These clear things look Ssswweeet !!! WHERE ARE YOU GUYS FINDING 11/16 CLEAR BRAIDED HOSE I DONT SEE IT AT HOME DEPOT OR LOWES JUST 3/4 AND 1 INCH Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted November 15, 2006 Report Share Posted November 15, 2006 You can use 3/4 it works fine. Just put it on about 30min ago. Seems to be fine to me gets alittle soft after you get it really hot but nothing i would worry about. Quote Link to comment Share on other sites More sharing options...
BANSHEEPRO Posted November 15, 2006 Report Share Posted November 15, 2006 You can use 3/4 it works fine. Just put it on about 30min ago. Seems to be fine to me gets alittle soft after you get it really hot but nothing i would worry about. 3/4 WONT GO ONE MY COOL HEAD THATS FOR SURE Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted November 15, 2006 Report Share Posted November 15, 2006 3/4 ID will go over it just take boiling water and let the hose sit in it for alittle bit. I had to do it to get it on the clutch cover one. Quote Link to comment Share on other sites More sharing options...
BANSHEEPRO Posted November 15, 2006 Report Share Posted November 15, 2006 3/4 ID will go over it just take boiling water and let the hose sit in it for alittle bit. I had to do it to get it on the clutch cover one. WELL ILL TRY AGAIN ILL LET YA KNOW Quote Link to comment Share on other sites More sharing options...
Satsol67 Posted November 15, 2006 Report Share Posted November 15, 2006 I have been thinking about this for sometime now. Its good to see others are trying it. I went to lowes the other day for a T fitting so i could install my temp sender for the gauge and all most bought the clear hose. Its crazy as hell to spend 99 bucks on the ones that ebay lists or rmatv. When my stock hose for the water pump broke I just used 3/4 heater hose from autozone but I would really like to change to the clear hose with some red die color. Quote Link to comment Share on other sites More sharing options...
IROOST1 Posted November 17, 2006 Report Share Posted November 17, 2006 That clear would look sweet and for that price, you can change it every couple rides. I personally run goodyear 3/4 inch heater hose from autozone. .99 /ft Quote Link to comment Share on other sites More sharing options...
