peterlocal22 Posted September 1, 2006 Report Posted September 1, 2006 just wanted to try a new set of handlebars and wasnt sure about the bend. what do you like best? 1 Quote
Polish Posted September 1, 2006 Report Posted September 1, 2006 (edited) I have tried a lot of bends.........ATV high, medium........raptor...ect ect! I have personally found that the Honda CR High (MX Bars)......seem to fit my style, there the pro taper Fat Bar........there a little wider and taller. I chose taller because I mostly ride on top of my Bars.........The RM Carmichael has a good bend also! I know you are looking to spend only $40.00............but here is a picture of my CR bend Edited September 1, 2006 by Polish Quote
ThE_BaNsHeE_mAn88 Posted September 1, 2006 Report Posted September 1, 2006 i have a set of trail tech fat bars and there atv low. i have low because i do more jumping and mx. i think it would be worth the extr money to get trail tech fat bars because i flip mine 3 times once on the road and they havent bent yet. my frame bent befor they did here they are. i got the bars for 62 and i got the clamp off some guy on yfz central new for 35. so look around and you can find some good ones. 1 Quote
shanYE west Posted September 1, 2006 Report Posted September 1, 2006 I use the Tag T2 kit for the Banshee. And I've used CR Dbl High bends Quote
gregbowler Posted September 1, 2006 Report Posted September 1, 2006 I run the renthal honda 400EX bend bars on mine. They're a little less pull back and a little taller than stock. Quote
okbeast Posted September 2, 2006 Report Posted September 2, 2006 I like my bars on the 400ex. If I ever need new bars for the shee, i'll probably get this bend just cuz I'm used to it and like it. Quote
Bansheeman1121 Posted September 2, 2006 Report Posted September 2, 2006 I got 400ex bend pro tapers on my shee im partin, jw if you would be interested they are my fav bend i have ever ridden with Quote
ClimbAnyHill Posted September 3, 2006 Report Posted September 3, 2006 I have tried a lot of bends.........ATV high, medium........raptor...ect ect! I have personally found that the Honda CR High (MX Bars)......seem to fit my style, there the pro taper Fat Bar........there a little wider and taller. I chose taller because I mostly ride on top of my Bars.........The RM Carmichael has a good bend also! I know you are looking to spend only $40.00............but here is a picture of my CR bend What did you replace your stock electrical controll with? Dont see it on the bars?? I see that button next to the grip, is that trail techs controll? Quote
Polish Posted September 3, 2006 Report Posted September 3, 2006 What did you replace your stock electrical controll with? Dont see it on the bars?? I see that button next to the grip, is that trail techs controll? I put a CR kill switch on.........and the lights stay on perminatly Quote
lonestar Posted September 3, 2006 Report Posted September 3, 2006 (edited) I like V bars. Had them on 3 wheeler also very comfortable for me, & cheap price wise. Almost like semi drag bars Edited September 3, 2006 by lonestar Quote
SandShots Posted September 3, 2006 Report Posted September 3, 2006 I have tried a lot of bends.........ATV high, medium........raptor...ect ect! I have personally found that the Honda CR High (MX Bars)......seem to fit my style, there the pro taper Fat Bar........there a little wider and taller. I chose taller because I mostly ride on top of my Bars.........The RM Carmichael has a good bend also! I know you are looking to spend only $40.00............but here is a picture of my CR bend hey dude, that handle bar settup looks badd ass with all that billet and braided lines. what did you do with the engire run/off switch? and what kind of light switch are you running for your lights. i can see a small switch on your left side and it looks low profile can barely see it. tight setup man. Quote
Polish Posted September 3, 2006 Report Posted September 3, 2006 (edited) hey dude, that handle bar settup looks badd ass with all that billet and braided lines. what did you do with the engire run/off switch? and what kind of light switch are you running for your lights. i can see a small switch on your left side and it looks low profile can barely see it. tight setup man. I put a CR kill switch on.........and the lights stay on perminatly...........real easy setup...........I think the switch was $9 - $11 bucks..................I elimated mostly all of my electrical crap..........and ran it nice and clean next to the frame..........here is pics I used a free flow vent tube to keep it away from the fram and pipe..........my camera sux so it might be a little hard to see..............I got the idea of the vent tube from Hot Rod Mag..........It looks like in the picture that it is touching the pipe, but its actuall 2" away Edited September 3, 2006 by Polish Quote
banshee364 Posted September 27, 2006 Report Posted September 27, 2006 I put a CR kill switch on.........and the lights stay on perminatly I put a YZ kill switch on mine and wired a toggle switch for the lights on bright. Mounted it behind the radiator. I have Pro Taper SE bars in the Carmichael Bend (MX). I have always had motorcycles, so I am used to the lower bends. This is a very low bend, medium pull back and pretty wide. Quote
Washburn Posted November 7, 2006 Report Posted November 7, 2006 I am thinking about buying the FLY bars 35 bucks. Or just putting my old LT250R bars on. I want a higher bar than stock 1/12 would be perfect. Quote
