Banshee battery
If you did mount a battery on your shee, you would need to run a higher output stator (ie 200-250 watts) plus install a regulator/rectifier to not overcharge the battery and keep it charged up. without those things the battery wouldn't charge very well with a lower wattage stator and overcharging it would destroy a perfectly good battery. Just my .02, but if anyone else has better info..................... :beer:
USE A PULSE PUMP.... NEEDS NO BATT
How about you need to do a DC conversion. That is why you need to install another regulator / rectifier. Your battery puts out DC (direct current). Your banshee's stator puts out AC (alternating current). They are not compatable. So you have to some rewireng on the stator and some with the banshee's wiring harness to get it to work.
Banshee DC Conversion LINK
josh
