Override Tranny
Rebel3190
It is a tranny where the gears are "cut", so they can be shifted without using the clutch. There are a few different kind of over rides such as a duneable. I don't ride dunes, and don't have an over ride, but more members here should be able to fill you in a little better. You can also try the serach, it has been discussed here a few times.
an over ride allows you to shift up at full throttle without the use of the clutch. regular over rides cant be down shifted until you come to a complete stop or youll bend the shift forks. duneable over rides can be shifted up and down with or without the use of a clutch and they wont bend shift forks. if you arent full drag then go with duneable, its well worth the money even for a trail rider.
I have a 2-5 dunable in my bike, one of the best mods I have done, never miss a gear again. I just called the guy off ebay and ordered my tranny straight from him. hit me up if you have anymore questions
JT...how come you didn't get the 1-5 instead? Just curious....
Did you keep or remove 6th gear?
I was told 1-5s where ment for ashfault so you can run real tall gearing and still be able to take off hard. I went 2-5 cause you dont have to shift as much, and I never used 1st anyway.
I removed 6th you cant have 6th with a 2-5, you can how ever get a 1-6 but you have to come to a complete stop to down shift, and they are prone to breaking.
I can vouch that an over-ride makes a huge difference when dragging. I took mine out but it wasnt a dunable one. I will probably get one of those when i put my new carbs on.
Absolutely no doubt. Between that and a lockup...I'm hoping to gain .2 to .3 seconds off my 300ft time, and...no more missed shifts or "Phantom Nuetrals"...
I love my pipes...but, if you shift just a hair early with the clutch and you're not on the pipe....your race is over....
