powerbanshee Posted August 21, 2006 Report Share Posted August 21, 2006 i was at silver lake today and rode for about 2 hours when i went to go up a big hill at wot and it cut out a little when i stopped it stalled and wouldn`t start, it tried to start but backfired a couple times, brought it back home and started to check it out, the spark plugs only sparked one out of every three kicks, so i put the coil of my 97 on it it`s a 87 and same thing, then i found a almost broken wire on the cdi box fixed that and still did the same thing, i pulled the stator cover but it looked alright but i don`t know what to check with that, any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 21, 2006 Report Share Posted August 21, 2006 Ohm test the stator and coil, see if you can borrow a CDI from someone. Do you have TORS? Quote Link to comment Share on other sites More sharing options...
powerbanshee Posted August 22, 2006 Author Report Share Posted August 22, 2006 Ohm test the stator and coil, see if you can borrow a CDI from someone. Do you have TORS? no tors, the cdi mof my 97 wouldn`t work cuz of different hook ups, but i found the problem, another wire was broke, that sucks i lost 5 hours of riding at silver lake for just a fricken wire, go figure, thanks for the help!!! Quote Link to comment Share on other sites More sharing options...
