00tbanshee Posted August 19, 2006 Report Share Posted August 19, 2006 my shee currently has the timing advance but not sure how far. the plate is turned about quarter of a inch. i was told that is about +7. my mods are a clean up port job, 19cc cut head thanx to rudy kurtz,ported rad valve cages with reeds, filter pods, t5's and running 115 octane fuel with 180psi of compression. how much timing do you think i can run? i only drag it at a 500ft. dirt track. Quote Link to comment Share on other sites More sharing options...
00tbanshee Posted August 19, 2006 Author Report Share Posted August 19, 2006 my shee currently has the timing advance but not sure how far. the plate is turned about quarter of a inch. i was told that is about +7. my mods are a clean up port job, 19cc cut head thanx to rudy kurtz,ported rad valve cages with reeds, filter pods, t5's and running 115 octane fuel with 180psi of compression. how much timing do you think i can run? i only drag it at a 500ft. dirt track. i was wrong it was only 1/8 in. i moved it a 1/4in. and it ran fine but only ran a couple min. and the pipes got pretty hot so moved it back to 3/8in. i am going to get a timing plate next week Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 19, 2006 Report Share Posted August 19, 2006 Stock Crank? It is welded? If not...you're wasting your time going any further... If yes... 8 to 10 degrees on a plate for 500ft drags is fine, as long as your jetting is dialed in... Quote Link to comment Share on other sites More sharing options...
RBD Posted August 19, 2006 Report Share Posted August 19, 2006 1/8" = about 3 DEGREES 1/4" = about 6 DEGREES Quote Link to comment Share on other sites More sharing options...
Polish Posted August 19, 2006 Report Share Posted August 19, 2006 My plate is 5 Degrees.......... Quote Link to comment Share on other sites More sharing options...
00tbanshee Posted August 19, 2006 Author Report Share Posted August 19, 2006 thanx Quote Link to comment Share on other sites More sharing options...
