Rebel3190 Posted August 17, 2006 Report Share Posted August 17, 2006 What the hell do reed spacers do as far as performance. Quote Link to comment Share on other sites More sharing options...
CadillacBanshee Posted August 18, 2006 Report Share Posted August 18, 2006 They are supposed to create a tunnel to let are flow better like the lungz bullshit. I took them off of my bike because they didnt help, but when i got my bike ported i threw them back on after a few rides and they made a small difference in acceleration. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 18, 2006 Report Share Posted August 18, 2006 What the hell do reed spacers do as far as performance. Nothing... They're used for clearing the clutch arm once you get bigger carbs...and...since you're putting bigger carbs on, you'll get a bigger increase in performance... Quote Link to comment Share on other sites More sharing options...
RBD Posted August 18, 2006 Report Share Posted August 18, 2006 What the hell do reed spacers do as far as performance. NOTHING !!! Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted August 18, 2006 Report Share Posted August 18, 2006 They are just like throttle body spacers on cars, absolutely useless. I had them on my bike, and I didnt notice a difference either, think they're laying in my trailer now. Maybe with biggercarbs, like said above it might make a difference? I don't know, but I couldnt tell any difference. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted August 18, 2006 Report Share Posted August 18, 2006 The idea behind reed spacers is they move the reeds further away from the piston in hopes of emulsifying the fuel and air charge more before it enters the engine. They make more mid-top power. I have a pwk 35mm carb bowl with a welded drain on it for clearing the clutch arm. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 18, 2006 Report Share Posted August 18, 2006 I have a pwk 35mm carb bowl with a welded drain on it for clearing the clutch arm. i as well have the bowl welded. but the spacers have nothing to do with performance, its an alternative to welding the bowl much like the jugs spacer and cutting domes for a long rod stroker.same solution for a problem just two differant way of fixing it. Quote Link to comment Share on other sites More sharing options...
