michigan_soler Posted August 15, 2006 Report Share Posted August 15, 2006 well, i just re-assembled the whole engine after shift problems and now it won't idle, i tried to adjust the cable but won't work... is there an adjustment on the carb that i can screw with to help with throttle. cuz if i just barly push down the throttle it will keep runnin, but thats it. also, having a leak now on the right pipe (well, its white smoke, so coolant, how do i fix this. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 15, 2006 Report Share Posted August 15, 2006 YOu need to fix your coolant leak before you worry about being able to idle. It's quite possible it'll idle fine after you fix that... Water/coolant in the jugs doesn't burn well. My guess is you didn't seal the base or head gasket correctly. Time to tear at least the top off (head) and get a new gasket. You did buy a new gasket and properly torque the head down in sequence, right? Did you clean up both surfaces, cylinder and head? Quote Link to comment Share on other sites More sharing options...
michigan_soler Posted August 15, 2006 Author Report Share Posted August 15, 2006 i just used a gasket scraper and cleaned them up like i would on the head of a car... can i pull off the head with it still in the bike or is that really hard? Quote Link to comment Share on other sites More sharing options...
Dinner Posted August 15, 2006 Report Share Posted August 15, 2006 I would take the engine out in my opinion. Because it is a lot easier to work on. It could be the head gasket or one of the bottom gaskets, so if it ends up being one of the bottom ones, you already have the engine out. Quote Link to comment Share on other sites More sharing options...
michigan_soler Posted August 15, 2006 Author Report Share Posted August 15, 2006 so i can't remove the bottom part, just the top part... i think im gettin it... its just kinda discuraging cuz i just put it all together and ran it in the garage, now i gotta rip it all out again. Quote Link to comment Share on other sites More sharing options...
