y2kbanshee9187 Posted August 12, 2006 Report Share Posted August 12, 2006 It seems fine in first and second and then at WOT in 3rd gear and up it misses for just a split second. I was thinking a piece of dirt in the carbs or just needed jetted because I just put on new pipes+reeds but Im not sure. Any ideas? thanks ben Quote Link to comment Share on other sites More sharing options...
steveodo Posted August 12, 2006 Report Share Posted August 12, 2006 Hey y2k you could try going up 1 on the mains since you piped it Quote Link to comment Share on other sites More sharing options...
y2kbanshee9187 Posted August 12, 2006 Author Report Share Posted August 12, 2006 I have a single carb. I have just been trying to play with the needle to see where it runs the best but its still missing. I need to go to dual carbs. Quote Link to comment Share on other sites More sharing options...
400ccStroker_shee Posted August 14, 2006 Report Share Posted August 14, 2006 (edited) I have a single carb. I have just been trying to play with the needle to see where it runs the best but its still missing. I need to go to dual carbs. If it misses when your WOT then its probably your main jet, if its the jetting. Also I prefer dual carbs to me it seems like you lose a little top end when you only have 1 carb Edited August 14, 2006 by 400ccStroker_shee Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 14, 2006 Report Share Posted August 14, 2006 Hey y2k you could try going up 1 on the mains since you piped it If you went from stock pipes to ANY aftermarket pipes, I hope you went up more than just one on the main. Y2K...help us to help you. List all your mods, elevation and temps you ride in. We'll take it from there.... Dual carbs are not always ideal for all riders/riding locale...If I were to build a trail shee, that's probably what I'd go with to be honest... Quote Link to comment Share on other sites More sharing options...
