noise when in nuetral and idling
Dcuzz23
i just got my quad all back together and i noticed a sound coming from the engine when its running and in nuetral. when i pull in the clutch it goes away. it sounds like rough to like the stator or something is loose but its not that. any ideas?
I PC'D THE FRAME, DID THE SUSPENSION, REBUILT TOP END, CLUTCH, STATOR +TIMING PLATE, THE LIST GOES ON. I DONT HAVE THAT RUBBER BUSHING BEHIND THE CLUTCH PLATES. AS SOON AS I PULL THE CLUTCH THE NOISE GOES AWAY AND ITS INTERMITTENT. SOMETIMES IT DOES IT SOME TIMES IT DONT BUT IT DEFINATELY SOUNDS LIKE IT COMING FROM THE STATOR SIDE. I HAD MY TOP CASE HALF REPLACED AND ALL NECCESARY GEARS IN THE PRIMARY DRIVE BECAUSE A YR AGO IN THE SNOW A CHUNK OF ICE BUILT UP ON THE CLUTCH LEVER(ON THE CASE) AND I PROCEEDED RIDING(VERY DRUNK) MAKE A LONG STORY SHORT I HEATED, SWELLED, AND SIEZED EVERY COMPONENT OF THE CLUTCH UP TITE AND MY ENGINE GUY DISSASEMBLED AND AND REPLACED EVERYTHING THAT WAS BAD. CLUTCH CHATTER MAKES SENSE BUT IM GONNA PULL OFF THE STATOR COVER JUST TO BE SURE. THANX
The stock clutch uses those rubber orings to get rid of that chatter...
Every aftemarket clutch I've seen does not use 'em.
You're probably ok, just check the flywheel and stator to be safe.
Please...don't use all caps when replying, it's the same as shouting on a computer...and annoying!!
absolutley.
mine does the same thing. not to worried about it, ive been through many topends with the same noise.
