Dcuzz23 Posted August 8, 2006 Report Share Posted August 8, 2006 i just got my quad all back together and i noticed a sound coming from the engine when its running and in nuetral. when i pull in the clutch it goes away. it sounds like rough to like the stator or something is loose but its not that. any ideas? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted August 8, 2006 Report Share Posted August 8, 2006 100 percent normal. Quote Link to comment Share on other sites More sharing options...
NYUK Posted August 8, 2006 Report Share Posted August 8, 2006 clutch chatter, new clutch no rubber rings? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 8, 2006 Report Share Posted August 8, 2006 Well, if it's coming from the stator side I'd worry, you might not have tightened something down. Clutch side...well, it's been said above.... You say you just put it back together, what exactly did you do while it was apart? Quote Link to comment Share on other sites More sharing options...
Dcuzz23 Posted August 9, 2006 Author Report Share Posted August 9, 2006 I PC'D THE FRAME, DID THE SUSPENSION, REBUILT TOP END, CLUTCH, STATOR +TIMING PLATE, THE LIST GOES ON. I DONT HAVE THAT RUBBER BUSHING BEHIND THE CLUTCH PLATES. AS SOON AS I PULL THE CLUTCH THE NOISE GOES AWAY AND ITS INTERMITTENT. SOMETIMES IT DOES IT SOME TIMES IT DONT BUT IT DEFINATELY SOUNDS LIKE IT COMING FROM THE STATOR SIDE. I HAD MY TOP CASE HALF REPLACED AND ALL NECCESARY GEARS IN THE PRIMARY DRIVE BECAUSE A YR AGO IN THE SNOW A CHUNK OF ICE BUILT UP ON THE CLUTCH LEVER(ON THE CASE) AND I PROCEEDED RIDING(VERY DRUNK) MAKE A LONG STORY SHORT I HEATED, SWELLED, AND SIEZED EVERY COMPONENT OF THE CLUTCH UP TITE AND MY ENGINE GUY DISSASEMBLED AND AND REPLACED EVERYTHING THAT WAS BAD. CLUTCH CHATTER MAKES SENSE BUT IM GONNA PULL OFF THE STATOR COVER JUST TO BE SURE. THANX Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 9, 2006 Report Share Posted August 9, 2006 The stock clutch uses those rubber orings to get rid of that chatter... Every aftemarket clutch I've seen does not use 'em. You're probably ok, just check the flywheel and stator to be safe. Please...don't use all caps when replying, it's the same as shouting on a computer...and annoying!! Quote Link to comment Share on other sites More sharing options...
racer Posted August 9, 2006 Report Share Posted August 9, 2006 Please...don't use all caps when replying, it's the same as shouting on a computer...and annoying!! absolutley. mine does the same thing. not to worried about it, ive been through many topends with the same noise. Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted August 9, 2006 Report Share Posted August 9, 2006 fewf , mine does the same thing and i was about to split the case , thought it was my tranny..... time to ride it till it dies Quote Link to comment Share on other sites More sharing options...
kawiking Posted August 9, 2006 Report Share Posted August 9, 2006 i had a noise for awhile like you said. ended up being my flywheel was loose as hell. didnt have the nut tightened down enough. Quote Link to comment Share on other sites More sharing options...
