Bill Posted August 4, 2006 Report Share Posted August 4, 2006 I know you haft to lath it but how much material do you take off?thanks Quote Link to comment Share on other sites More sharing options...
dashee03 Posted August 4, 2006 Report Share Posted August 4, 2006 (edited) I know you haft to lath it but how much material do you take off?thanks Mine is getting lightened now I think boonman takes off around 8 oz. Edited August 4, 2006 by dashee03 Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted August 4, 2006 Report Share Posted August 4, 2006 Your lathe also has to have a tapered hub to hold it center. Boonie did mine as well as my shift star and I couldn't be happier...... Quote Link to comment Share on other sites More sharing options...
rocketboy Posted August 6, 2006 Report Share Posted August 6, 2006 it has to be machined/trued off a banshee crank to run true and concentric or it may possibly vibrate and/or explode Quote Link to comment Share on other sites More sharing options...
Bill Posted August 7, 2006 Author Report Share Posted August 7, 2006 Just running it on A lath would'nt keep it true? Quote Link to comment Share on other sites More sharing options...
racer Posted August 7, 2006 Report Share Posted August 7, 2006 how are you going to hold it? i surely wouldnt put my flywheel in some lathe jaws. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 7, 2006 Report Share Posted August 7, 2006 (edited) do you have to ballance it when your done ?? has any body added weight? Edited August 7, 2006 by 275hp banshee's Quote Link to comment Share on other sites More sharing options...
Dmcbanshee Posted August 7, 2006 Report Share Posted August 7, 2006 do you have to ballance it when your done ?? has any body added weight? Why added weight? I remove 3/16'' on mine and yes need to be balanced Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 10, 2006 Report Share Posted August 10, 2006 Why added weight? I remove 3/16'' on mine and yes need to be balanced bottom end more controllable comming on the pipe & longer pipe band cornering, trails Quote Link to comment Share on other sites More sharing options...
fastcar01 Posted August 10, 2006 Report Share Posted August 10, 2006 bottom end more controllable comming on the pipe & longer pipe band cornering, trails This is what I was thinking. Most of the time you add weight, but that may be only for single cylinders, not doubles. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 10, 2006 Report Share Posted August 10, 2006 This is what I was thinking. Most of the time you add weight, but that may be only for single cylinders, not doubles. yeh heard it from old school dirt biker Quote Link to comment Share on other sites More sharing options...
kawiking Posted August 10, 2006 Report Share Posted August 10, 2006 my buddy and i both had are's done. he got his done first,the guy drilled holes in the side to cut out alittle wieght(not mine).long story short,3 weeks ago his fly wheel split in half!!! dont drill holes in it. i think mine had 4 holes drilled in it. his had holes all around it. how much does a stock fly wheel wieght. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted August 10, 2006 Report Share Posted August 10, 2006 I've seen a lot of them explode from people trying to just toss them in a lathe and start chopping. You have to have a centering wheel for one and you have to have a way to balance the flywheel after you are done cutting. Its not just throw it in there and buzz it with your tool and bolt it back on the bike. It might work and be what your looking for, but in most cases under a year it will crack and explode inside your sidecover. I've also seen them take out crank bearings from being out of balance. Quote Link to comment Share on other sites More sharing options...
