Cub Octane?
Same old stuff... What altitude are you at? What size domes do you have? Go do a compression test real quick and tell us what it reads.
Without changing domes you could probably bump up to +7 timing and still be safe.
I run +9 timing on mine, but I run a special fuel we make ourselves, and I'm at 7500ft so I won't ever have anywhere near the compression someone at lower altitudes would. The fuel we make ends up with an octane rating somewhere between 125 and 135.
my cub is set up for pump gas and was considering running sum 112 my timing is at +4 how much can i advance it with the 112?
+4 should work and you can probally go to +6 on your timing with the 112
if your at 7500 ft why would you run a fuel with an octane rating of 125-135 ?i would think 91 or 93 would be enough.
"What altitude are you at? What size domes do you have? Go do a compression test real quick and tell us what it reads" Bigred
im at sea level to 500ft got 20cc domes wish i had a gauge really need to invest in one should be around 150 or so
"If you have no problem running 112 octane, I'd bump that timing up to 8 or 10. Cubs love timing and compression...."
i havent ran it yet but it should run just fine with it i just want to kno how much timing i can get away with
what size mains are u guys runnin also ?
thanks for the replies guys
I run the higher octane for a couple reasons... Look at how much timing I run, and what size domes I have. I also have some 16cc domes I put in depending on what I'm doing. My compression is high enough I would at least need to run 50/50 at this altitude and since I just about maxed out my timing plate I went ahead and run the higher stuff we make.
We make our own fuel. Its a mix of a bunch of different things, the combination actually makes the higher octane rating, its not like I'm going out buying something that high, its just a side-factor to the "manufacturing" process we use and some of the ingredients.
Edited by BigRed350x
Shit red...if you maxed out a Ricky Stator timing plate, it's more like 12 degrees!!!
