Installing T-5's
I am putting T5's on my bike and I have not messed with it a ton yet, but they did not seem to want to go on. Do I need to disconnect the fender mount bar? Or do I just slip them in there? Toomeys web site makes it sound like you just turn the wheel and they slip right in. I was pretty hung over when I tried, so I got fed up real fast. I am doing it tonight, and just wonderin if there is a trick or tip to install them.
Thanks
I think you have to remove the front fender brace. Before my fenders where cut i always took the braces off cause it was a hell of a lot easier.
I think we covered the tips for those pipes, Dale....
I had a bear of a time, and I even put the bike on the grab bar to put 'em on.
Then...I got smart...as I PM'd ya...I put just a bit of grease on the Orings, and they slid right on.
Those babies came off no problems with my stock motor, and no issues at all with my cub, too...
I know they're a pain sometimes, but...if you get stuck, bring 'em back to my garage, and I'll put 'em on, jet your carbs and sync them up for you too...
Hell, if you wanna pick up a TORS removal kit, I'll take care of that for you as well. I have the tap and drill, you'll need the new carb caps, brass screws and locknuts, and new cable. I have a cable, but...wouldn't trust it other than for a backup....
Hung Over? Sounds like you might have had too much fun at that concert. Hung over in 90 degree plus heat is not the best time to work on your shit...trust me on that one!!!
My toomeys never fit right for me... ever. I think they measured off a bent frame when they manufacture those things or something. LOL I actually had to drill new holes in every mount on the damn things to get them to fit.
My CPI's bolted right up, no problems.
you need to remove the frnder brace. also grease or wd40 the orings before installing them.
my toomeys bolted right up, but the pipe to stinger clamp awalys leaks. what a piece of shit. youd figure when buying some expensive ass pipes you could get a really good coupler but they dont include anything. they want you tyo use the stock ones which dont even fit because the stinger and pipe are each 2 different diamaters.
For 20 bucks and 4 hose clamps mine never leaked...
I bought a high temp rubber hose for each side from Magic racing...and they never leaked.
In fact, I am still using these same hoses for my RDZ pipes...no issues.
I am, however...in the market for a nice billet clamp to clean up the look a bit.
The billet clamps sure do look nice....
Not trying to be a smart ass...but, the OD of the pipe should be a different OD than the stinger tube it connects or slides into.
I bought the hose from Magic, and put two hose clamps on...done deal...
One on either side of the connection...
Yeah I didn't find this to be much of a problem, just one clamp is thight than the other. I am not surew if it is leaking, but it seems to be sealed there.
