jbooker82 Posted September 8, 2006 Report Share Posted September 8, 2006 I was going to order some diff Klotz formulas but I was wondering will these heavier oils mix easily in the gas tank itself? I am forced to do this from time to time. I use Amsoil Interceptor now and I have done this on many occasions and not had a problem. Will Koltz? It would mix just as good. It is a thicker oil but your still mixing it with gas wich thins it down. I would just make sure that you have the fuel turnd off so you dont get strait oil in the carbs. Then I would just stand on the pegs and rock it back and fourth to make sure. Quote Link to comment Share on other sites More sharing options...
HULKAMANIA Posted September 9, 2006 Report Share Posted September 9, 2006 If its not Klotz Super Techniplate, then its not being run through my machine plain and simple. Quote Link to comment Share on other sites More sharing options...
righteyeblind Posted September 13, 2006 Report Share Posted September 13, 2006 927 is real dirty and smokes a lot TORCO gp7 is the only way to go Quote Link to comment Share on other sites More sharing options...
tpete3 Posted September 13, 2006 Report Share Posted September 13, 2006 Klotz Super Techniplate Quote Link to comment Share on other sites More sharing options...
r/atvshee Posted September 13, 2006 Report Share Posted September 13, 2006 927 is real dirty and smokes a lot TORCO gp7 is the only way to go sometimes smoke is good to tell if both cylinders are firing............ive ran 927 for a couple of years and no problems Quote Link to comment Share on other sites More sharing options...
Screaming Yellow Zonker Posted September 20, 2006 Report Share Posted September 20, 2006 If its not Klotz Super Techniplate, then its not being run through my machine plain and simple. That is the only oil I have ever used since I got my bike. I rebuilt the topend 4 years ago and my bike still runs strong. I run my bike fat at 32:1 just to keep heat down and it is cheaper to replace plugs than pistons. Quote Link to comment Share on other sites More sharing options...
black sunshine Posted September 20, 2006 Report Share Posted September 20, 2006 Just picked up some R50, have to get rid of the rest of my amsoil first. I was shied away from the supertechniplate cause it said it was strictly for high rpm racing use only. Wrong?? Quote Link to comment Share on other sites More sharing options...
prichard9966 Posted September 21, 2006 Report Share Posted September 21, 2006 i run yamalube at 32:1 with some amoco premium in all my bikes, weed eater,chain saw and mower. i run it at 36:1 with some 110 leaded in my passion motor. i really like the stuff but thats me Quote Link to comment Share on other sites More sharing options...
hotrodbanshee Posted September 22, 2006 Report Share Posted September 22, 2006 I have been running the castor 927 for 3 years and get alot of carbon buildup on pistons and inside my pipes. I am thinking about switching to belray H1R synthetic premix. Is this a good oil to run? Quote Link to comment Share on other sites More sharing options...
BaNsHeeJuNkEy Posted September 22, 2006 Report Share Posted September 22, 2006 ok i have been running gold spectrum 50/1 in my bike with 104 octan. wanted to knwo a few things. am i better off running klots technoplates or stayn with what i am using. also am i better off running 42/1 instead 50/1 on my bike. i do a lot of trail ridin, racing every now and then and lots of jumps and wheelies. and i would also like you opinnion on motor or for my quad. it is a 03 shee. i know not to use synthetic because it will make clutch slip. what what is a good oil to use. and a shee take 10w/30 right. Quote Link to comment Share on other sites More sharing options...
Malfnet1 Posted October 2, 2006 Report Share Posted October 2, 2006 I use Klotz Super Techniplate the guy i bought my shee from ran Golden Spectrol and the klotx runs cleaner than that did and my local Yamaha and Honda Dealers (who i have friends at) both recomend the Klotz at 32:1. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 2, 2006 Report Share Posted October 2, 2006 Just picked up some R50, have to get rid of the rest of my amsoil first. I was shied away from the supertechniplate cause it said it was strictly for high rpm racing use only. Wrong?? I think your were looking at Klotz Benol. It says for racing use only. The supertechiniplate is like 80%R50 and 20% Benol Castor oil. Quote Link to comment Share on other sites More sharing options...
mod quad 2 Posted October 3, 2006 Report Share Posted October 3, 2006 im just switching to ams domintar i ride trails and pits mostly maybe some mx in the future but will it be safe to ride 50:1 or do 40:1 Quote Link to comment Share on other sites More sharing options...
atvaddiction Posted October 4, 2006 Report Share Posted October 4, 2006 I agree fully with what u said. I use benol in my banshee and have not had nay problems. I ran out of benol one time and wanted to ride so I used the ''cheap crap'' for one ride and I had a really hard time startin my banshee (1-2 kicks with benol). And the benol burns through so much better. :biggrin: AmsOil LINK Look at the specs at the bottom of the page. Compare them to Klotz Super Techniplate. Klotz Supertechniplate Data LINK Amsoil Flash point. 198 deg Super Techniplate Flash point. 460 deg Flash point it the temperature where it starts to burn but when the ignition source is removed it will not continue to burn. Fire point is were it starts to burn and will keep burning on it own when the ignition source is removed. Usually the Fire Point is a few degrees higher than the Flash Point I bet your banshee's cylinders run hotter than 200 deg. Amsoil Viscosity. cSt @ 40 deg 40.9 Super Techniplate cSt @ 40 deg 200 At 100 deg super techniplate is like 50 weight oil. Wich one do you think gives a better protective film of oil. I would bet on the thicker one. Klotz Benol has even higher specs. Klotz Benol Data LINK RPM Limit = Unlimited Here is Klotz R50 for the heck of it. Klotz R50 Data LINK I am not knocking Amsoil just pointing out some facts. Klotz's other oils like Motorcycle Techniplate TC-W2 and TC-W3 have specs comparable to your Amsoil Dominator. Just when using oil that can be used for automatic oil injection it is going to be a thiner oil so it can work with the injection pump. I figure that I might as well use a good thicker oil since you dont have to worry about oil injection. Quote Link to comment Share on other sites More sharing options...
Bandit Posted October 29, 2006 Report Share Posted October 29, 2006 I run amsoil...good stuff Quote Link to comment Share on other sites More sharing options...
