Rebel3190 Posted July 24, 2006 Report Share Posted July 24, 2006 I just installed a new set of cylinders bored .100 over and a milled head,these cylinders were run on AmsOil Dominator,now should i run the same oil that these cylinders were run on or should i switch to something else,also what are the advantages of switching to synthetic,another question with my motor at sea level am i going to need to run race gas,and where can i buy it from? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 24, 2006 Report Share Posted July 24, 2006 I just installed a new set of cylinders bored .100 over and a milled head,these cylinders were run on AmsOil Dominator,now should i run the same oil that these cylinders were run on or should i switch to something else,also what are the advantages of switching to synthetic,another question with my motor at sea level am i going to need to run race gas,and where can i buy it from? AmsOil LINK Look at the specs at the bottom of the page. Compare them to Klotz Super Techniplate. Klotz Supertechniplate Data LINK Amsoil Flash point. 198 deg Super Techniplate Flash point. 460 deg Flash point it the temperature where it starts to burn but when the ignition source is removed it will not continue to burn. Fire point is were it starts to burn and will keep burning on it own when the ignition source is removed. Usually the Fire Point is a few degrees higher than the Flash Point I bet your banshee's cylinders run hotter than 200 deg. Amsoil Viscosity. cSt @ 40 deg 40.9 Super Techniplate cSt @ 40 deg 200 At 100 deg super techniplate is like 50 weight oil. Wich one do you think gives a better protective film of oil. I would bet on the thicker one. Klotz Benol has even higher specs. Klotz Benol Data LINK RPM Limit = Unlimited Here is Klotz R50 for the heck of it. Klotz R50 Data LINK I am not knocking Amsoil just pointing out some facts. Klotz's other oils like Motorcycle Techniplate TC-W2 and TC-W3 have specs comparable to your Amsoil Dominator. Just when using oil that can be used for automatic oil injection it is going to be a thiner oil so it can work with the injection pump. I figure that I might as well use a good thicker oil since you dont have to worry about oil injection. Quote Link to comment Share on other sites More sharing options...
Rebel3190 Posted July 24, 2006 Author Report Share Posted July 24, 2006 where can you buy the klotz supertechniplate and is it synthetic? Quote Link to comment Share on other sites More sharing options...
RILS Posted July 24, 2006 Report Share Posted July 24, 2006 where can you buy the klotz supertechniplate and is it synthetic? Ive alway ran maxima castor 927 and never had a problem related to the oil. Quote Link to comment Share on other sites More sharing options...
Dmcbanshee Posted July 24, 2006 Report Share Posted July 24, 2006 I always run with Amsoil Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 25, 2006 Report Share Posted July 25, 2006 where can you buy the klotz supertechniplate and is it synthetic? Last time i bought mine from rockymountain. Klotz Super Techniplate is a pure synthetic oil blended with 20% of there Benol Racing Caster Oil. Klotz R50 is a full synthetic that burns really clean. Benol has really good film strength but it is a caster oil and it does not burn as clean as the others. Super Techniplate is supose to be the best of both worlds of synthetic and caster oil. Super Techniplate at Rocky Mountain LINK Ive alway ran maxima castor 927 and never had a problem related to the oil. Maxima 927 is a good oil too. Is is a blend of synthetic oil and caster oil as well. Maxima 927 Link Quote Link to comment Share on other sites More sharing options...
Rebel3190 Posted July 25, 2006 Author Report Share Posted July 25, 2006 Alright,im between the maxima castor 927 or klotz super techniplate which should i use im gonna be doin a little draggin,lotta dunin,and ridin down backroads and stuff like that. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 26, 2006 Report Share Posted July 26, 2006 (edited) Premix oil is a Ford vs Chevy war. It is all about preferance. Get a quart of each. Try both of them and run the one you like. Edited July 26, 2006 by jbooker82 Quote Link to comment Share on other sites More sharing options...
csrmel Posted July 26, 2006 Report Share Posted July 26, 2006 castrol grand prix 2 stroke racing oil which is available at walmart for $2.30 a quart. Quote Link to comment Share on other sites More sharing options...
apbt549 Posted July 27, 2006 Report Share Posted July 27, 2006 i have always ran maxima castor 927 and never had a problem..but like jbooker said its like ford vs chevy...... Quote Link to comment Share on other sites More sharing options...
barely legal racing Posted July 27, 2006 Report Share Posted July 27, 2006 i have always ran maxima castor 927 and never had a problem..but like jbooker said its like ford vs chevy...... i used to run techniplate until the dealer here stopped carrying it, they recommended castor 927, ran about 5 tanks through and smells just like klotz, i cant tell a difference between them, other than the color, castor is yellow so you cant hardly tell when you pick up a jug if its mixed or not, but i think its really good oil, and about the same price. i am going to continue to run castor but id go to techniplate if they had it Quote Link to comment Share on other sites More sharing options...
sandman121383 Posted July 27, 2006 Report Share Posted July 27, 2006 if u didn't already break it in with a nonsynthetic oil. then switch to whatever u planned on. i myself ran amsoil , after reading this i'm going to be goin with klotz for my new pistons. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 27, 2006 Report Share Posted July 27, 2006 I just prefer to run a oil that is a heaver weight and has a high flash temperature. These oils are pre mix only. You might notice a little more oil coming out the exhaust pipe. That is becuase it isnt burning and turning to smoke. Right now i have 2 quarts of Maxama 927 and 2 quarts of Super Techniplate. I run the Super Techniplate all of the time but i bought a 2 quart bottle of the 927, just going to try it. Quote Link to comment Share on other sites More sharing options...
knight_ripper Posted August 24, 2006 Report Share Posted August 24, 2006 BEL-RAY synthetic pre-mix. 32:1. I order it by the case. I went and got sponsored by them cuz I love their products soo much. my mechanic tells me not to change a thing....I DONT. Quote Link to comment Share on other sites More sharing options...
lonestar Posted August 24, 2006 Report Share Posted August 24, 2006 motul = no carbon build up. 927 to dirty for me Quote Link to comment Share on other sites More sharing options...
