Layfield11 Posted July 21, 2006 Report Share Posted July 21, 2006 My banshee is loading when it is idling, but once you clear it out and take off it is okay, is that normal? any help would be great. Quote Link to comment Share on other sites More sharing options...
96dragbanshee Posted July 21, 2006 Report Share Posted July 21, 2006 clean out the carbs. That is not normal. The fact that you tell me it stops once u take off tells me its dirty in there. Mains could be wrongs as well. you might want to post this in carb and jetting forum and see if they can get you more help. Quote Link to comment Share on other sites More sharing options...
sredish Posted July 21, 2006 Report Share Posted July 21, 2006 it's not normal, your probably just a tad rich on the pilots. does it start cold w/o the choke? if so, then that's not normal either, you should need the choke to cold start, but not need it to warm start... Quote Link to comment Share on other sites More sharing options...
Layfield11 Posted July 22, 2006 Author Report Share Posted July 22, 2006 I dont ever haft to use my choke, i screwed the air pilots out some but i dont rem right off hand how many turns i have turned it out, it seems to help it the furthur i turn my pilots out, is this a bad idea or should i adjust it back to factory settings and work on something else? thanks for the help Quote Link to comment Share on other sites More sharing options...
