liquedfire Posted July 21, 2006 Report Share Posted July 21, 2006 (edited) well i burnt about a takn of gas so far and was wondering cold it will start on the 3rd kick every time run mint as i took it out today for about an hour it an fine but as i pulled into the yard and shut it off and tried 2 start it again it wouldent fire i pulled the choke out and it fired and died (lol on the 3rd kick again) then i kicked it without the choke on and it started and ran mint (purrd like a kitten) just was wondering what could cause this hard 2 start problem any help would be awsom thanks :baseball_bat: Glenn Edited July 21, 2006 by liquedfire Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 21, 2006 Report Share Posted July 21, 2006 What is your jetting at? How do your plugs look? have you done a compression test lately...? If all those check out, normaly it's electrical...when it heats up, it gets very stubborn. You can check the coil and leads as well as the stator with an OHM meter...specs and how to test are in any clymers manual. Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted July 22, 2006 Report Share Posted July 22, 2006 I sorta have the same problem- when its nice outside (round 70 to 80 deg.) shee'll start first kick EVERY time. but when its hot out, like it is now, i have to choke one of my carbs to get her goin. Ive got all the compression in the world, plugs are perfect(or damn close), and shee runs killer. Could i also have an electrical problem???? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 22, 2006 Report Share Posted July 22, 2006 Normally...electrical problems surface when the bike has run a bit (the part itself heats up from use)... or, it won't work at all. I don't know squat about the Lectrons...is it possible they need a cleaning? Normally...the warmer it gets, the less you need the choke... I also know the Lec's aren't as finicky with temp changes are the Miks and Keihins though... YOu said compression is good, make sure your tank filter (fuel valves) are clean, clean lines and clean carbs... What oil/premix you running? What plugs? Is you ignition all stock? For giggles, what is your elevation and compression reading? Quote Link to comment Share on other sites More sharing options...
liquedfire Posted July 22, 2006 Author Report Share Posted July 22, 2006 (edited) top end is brand new i did a chop test and the plugs are mint im runnin 30:1 yamaha lube 2R high octane i live in ottawa but i dono how high i am LOL everything is stock but what my sig says if u need 2 know anything eles let me know Edited July 22, 2006 by liquedfire Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 22, 2006 Report Share Posted July 22, 2006 What is the actual compression? Check for dirt in the carbs and/or fuel tank... Quote Link to comment Share on other sites More sharing options...
creamsickle Posted July 23, 2006 Report Share Posted July 23, 2006 coild tend to heat up and the wire expands and can lose its ability to have a strong spark. so if you have a friend who also has a banshee see if you can steal their ignition coil and then try it to see if there is a problem after it gets hot. Quote Link to comment Share on other sites More sharing options...
liquedfire Posted July 24, 2006 Author Report Share Posted July 24, 2006 kool i will try to steal his coil and the comp is 175psi both pistons hot and when its cold 180psi Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 24, 2006 Report Share Posted July 24, 2006 Odd...normally, the PSI raises when it's hot and it's a bit lower when cold. Did you hold the throttle WOT when you checked compression? What octane gas are you running? I have a spare coil. If you want to pay for shipping...on your honor, I'll ship it to you to test. Ship it back when you're done...or we can work out a price for it should you decide to keep it. But...testing with a buddies will obviously be easier.. Normaly, the wires are ok, but the end caps go bad. NGK end caps are pretty cheap...pick some of those up before you go buy another coil. Quote Link to comment Share on other sites More sharing options...
liquedfire Posted July 24, 2006 Author Report Share Posted July 24, 2006 thanks man but ya when i did the comp test i had it wide open thank you for the offer of your coil ill see if i can get my buddys if not i might hit u up pm me after and will talk thanks again glenn Quote Link to comment Share on other sites More sharing options...
