joshv5.0 Posted July 17, 2006 Report Share Posted July 17, 2006 it seems to be in a/c voltage by kicking it over i'm getting about 3 volts at the coil (orange and black wires) does this seem about right? Quote Link to comment Share on other sites More sharing options...
BenBB Posted July 18, 2006 Report Share Posted July 18, 2006 Yes it's AC, not sure exactly how many volts it oughta have but according to this RZ350 electricals page you oughta have at least 0.4V while kicking it over...the system is very similar though and the coils interchangable... Quote Link to comment Share on other sites More sharing options...
TREELIZARD Posted July 18, 2006 Report Share Posted July 18, 2006 (edited) stator resistance : ignition coil should be 13.7-20.5 ohms ( red to green wire ) pickup coil should be 94-140 ohms ( white/red to white/green wire ) lighting coil should be 0.26-0.38 ohms ( black to yellow wire ) coil resistance: primary coil should be 0.28-0.38 ohms secondary coil should be 4,700-7,100 ohms pickup coil gap: 0.015"-0.020" Edited July 18, 2006 by TREELIZARD Quote Link to comment Share on other sites More sharing options...
joshv5.0 Posted July 18, 2006 Author Report Share Posted July 18, 2006 stator resistance : ignition coil should be 13.7-20.5 ohms ( red to green wire ) pickup coil should be 94-140 ohms ( white/red to white/green wire ) lighting coil should be 0.26-0.38 ohms ( black to yellow wire ) coil resistance: primary coil should be 0.28-0.38 ohms secondary coil should be 4,700-7,100 ohms pickup coil gap: 0.015"-0.020" yea i checked everything else and found a bad stator and coil. i just replaced the stator and wanted to make sure i was getting enough volts out of it. now i guess i need to replace the coil Quote Link to comment Share on other sites More sharing options...
