juddthedstud Posted July 17, 2006 Report Share Posted July 17, 2006 Anyone ever weld the footpegs on. I know where there is a banshee but the pegs are welded on. does this work or will it trash the frame. also can you still get the motor out with the pegs welded on. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 17, 2006 Report Share Posted July 17, 2006 I'd say as long as they are lower than stock, or even with the frame, you'll be ok. Good luck getting the side cover off, let alone the motor out with welded footpegs as high as stock... Quote Link to comment Share on other sites More sharing options...
Bansheeman1121 Posted July 17, 2006 Report Share Posted July 17, 2006 Yup got one of my pegs welded on u can pull the motor and everything no probs wit it other than your freinds bust your balls and your quad might get labled the flying rat trap :shoothead: Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted July 17, 2006 Report Share Posted July 17, 2006 Just weld new mounts on or cut new threads and use a bigger bolt. Welding them on is retarded. It will make things far more difficult than they need be when working on your engine. If you do go the stupid route, make sure they are down low. Don't you think if yamaha wanted them to be non-removable they would have done that themselves? They come off for a reason... Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted July 17, 2006 Report Share Posted July 17, 2006 Sounds like someone knew how to weld, but couldn't figure out how to use a tap and die set........ Quote Link to comment Share on other sites More sharing options...
