liquedfire Posted July 16, 2006 Report Share Posted July 16, 2006 my bike is smoking more on the right side as to the left side it runs GREAT but just wondering if this is normal thanks Glenn Quote Link to comment Share on other sites More sharing options...
Dinner Posted July 16, 2006 Report Share Posted July 16, 2006 Could be your Crank Case Gasket, letting some oil drip in and getting burnt up. Is it at idle, or like idle all the way to WOT? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 16, 2006 Report Share Posted July 16, 2006 Mine did that too. Check your Trans oil level. My crank seal was bad and it was burning oil. That kind of explains the smoking more on the right hand trans side. Quote Link to comment Share on other sites More sharing options...
liquedfire Posted July 16, 2006 Author Report Share Posted July 16, 2006 well i took y carbs and my pipes off 2 do a crank case pressure test and the bottom end held 6psi for 6min Seals are good could it be float hight?????? thanks for the help Quote Link to comment Share on other sites More sharing options...
gipperz Posted July 16, 2006 Report Share Posted July 16, 2006 Do both cylinders have the same compression, do a compression check, check to see if carbs are in sync. Just some ideas, good luck to ya. Quote Link to comment Share on other sites More sharing options...
liquedfire Posted July 17, 2006 Author Report Share Posted July 17, 2006 yup both pistons are at 175 psi and both carbs are opening at the same time float levels are the same lol i dono relly Quote Link to comment Share on other sites More sharing options...
