BrianEb Posted July 13, 2006 Report Share Posted July 13, 2006 Trying to dial in my jetting here is my current set-up: Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 14, 2006 Report Share Posted July 14, 2006 I'm going to assume the T6's are close to the T5's in jetting. Are you using the Toomey needles (dynojet) or the stockers? Stockers, 3rd clip (middle) Toomey Needles 4th groove from the blunt end (6 total) 25 Pilots, 340 mains is what I ended up with whether I used the foam 1 into 2 filter of my K&N Pod clamp ons. Start the air screws at 1 turn out. Adjust the air screws until that bog goes away... Quote Link to comment Share on other sites More sharing options...
BrianEb Posted July 14, 2006 Author Report Share Posted July 14, 2006 Yeah I;m using the Dynojet needles If you don't start on the blunt end the clip is on the 3rd slot from the bottom I switched back to a #25 pilot last night and everthing seems to be alright 1.5 turns out from seated position on air screw Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 14, 2006 Report Share Posted July 14, 2006 Pefect... If you decide to go with VForce Reeds or other aftermarket cages, you might have to bump that clip up one...(leaner) to the blunt end. Glad to hear!! Quote Link to comment Share on other sites More sharing options...
