jbooker82 Posted July 6, 2006 Report Share Posted July 6, 2006 What size of filters is every body running. I was looking at some UNI Filters for my Keihin PJ34mm carbs. I am not sure if i want to use UNI foam filters or K&N. I was just kind of wondering about how long, what diameter of the actuall filter element (not the part that clamps on to the carbs) and what kind of base is everybody running. Most people just use a straight base or something like a 15 deg angled base? Some K&N part numbers would be great so i can see what all the measurments are. Quote Link to comment Share on other sites More sharing options...
CadillacBanshee Posted July 6, 2006 Report Share Posted July 6, 2006 You can look up part numbers on www.rockymountainatv.com and they have the lowest prices on k&n. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 6, 2006 Report Share Posted July 6, 2006 http://www.rockymountainatv.com/productDet...40&navType=type Measure the OD of the bell on the carb. Check with Magic Racing, too. I know for stock carbs, they have a steal on a twin pod kit w/ outerwears and a coolant resevoir bracket, like 69 or 79 bucks. That's cheap! Quote Link to comment Share on other sites More sharing options...
differentstrokes Posted July 7, 2006 Report Share Posted July 7, 2006 Motoman sells the same kit for $69.99, I've always had really good luck with them and Magic Racing. Check their site WWW.MOTO-MAN.COM 1 Quote Link to comment Share on other sites More sharing options...
sweetquads Posted July 7, 2006 Report Share Posted July 7, 2006 Motoman sells the same kit for $69.99, I've always had really good luck with them and Magic Racing. Check their site WWW.MOTO-MAN.COM Try K&N PN RU-0610, but my carbs are not stock so i dont remember what the stock ones take. Maybe the same? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 7, 2006 Author Report Share Posted July 7, 2006 Well my carbs are not stock ethire. They are Keihin Pj34 mm carbs. I was just kind of wanting a measure ment of how long and diameter of the fitlers. Then i can do a search on KN's web page for the filter that will clamp on my my size of carbs. I just dont want to get a filter that is to long or one that is to big around and have it rub on the frame or exhaust. Do most people use one that has the straight base, or one that has an angled base. Thanks for the links I will do some more investigatin. josh Quote Link to comment Share on other sites More sharing options...
RILS Posted July 7, 2006 Report Share Posted July 7, 2006 Well my carbs are not stock ethire. They are Keihin Pj34 mm carbs. I was just kind of wanting a measure ment of how long and diameter of the fitlers. Then i can do a search on KN's web page for the filter that will clamp on my my size of carbs. I just dont want to get a filter that is to long or one that is to big around and have it rub on the frame or exhaust. Do most people use one that has the straight base, or one that has an angled base. Thanks for the links I will do some more investigatin. josh I bought a set for 34pjs yesterday with outerwears from magic racing for around 80 dollars.Cascade has them also for 82 dollars i believe and if you get the part# you can order them at advanced auto atleast the store wher i live.But you if need the outerwears anyway you might as well buy the kit. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 7, 2006 Report Share Posted July 7, 2006 No matter what I did, they will rub on my stinger tubes from my T5. I have the angled ones for my PWKs. I found these so I don't melt my outerwears and filters!!! http://webforce.nwrain.net/founder/cascade...ORE_DEPT_ID=168 Quote Link to comment Share on other sites More sharing options...
differentstrokes Posted July 7, 2006 Report Share Posted July 7, 2006 If you want filters for PJ and PWK's check Eddie Sanders Racing, they should list the dimensions and angles on their site or give them a call and they'll set you up. They carry everything you are looking for and the clamp on kits are $40 or less, but you have to buy the outerwears separately (which they carry). I forgot to mention them in my first post since I was thinking stock carbs for some reason. Jared Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted July 8, 2006 Report Share Posted July 8, 2006 I use k&N pods from Packard Ent. the big one is for my lectrons-and the other is for stockers P.S. maybe size does'nt matter, but it sure helps!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
differentstrokes Posted July 8, 2006 Report Share Posted July 8, 2006 I use k&N pods from Packard Ent. the big one is for my lectrons-and the other is for stockers P.S. maybe size does'nt matter, but it sure helps!!!!!!!!!!!!!! That's the freakin' john holmes of air filters. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 9, 2006 Author Report Share Posted July 9, 2006 I bet with filters like that it is like having no filter at all. Quote Link to comment Share on other sites More sharing options...
lonestar Posted July 9, 2006 Report Share Posted July 9, 2006 That's the freakin' john holmes of air filters. I was thinking the same thing. good old johny Quote Link to comment Share on other sites More sharing options...
sweetquads Posted July 9, 2006 Report Share Posted July 9, 2006 I was thinking the same thing. good old johny Hey lonestar, i have the same setup as you (535 PV Cheetah) you ever dynoed your motor? Quote Link to comment Share on other sites More sharing options...
87banman Posted October 3, 2006 Report Share Posted October 3, 2006 i have stock carbs with UNI PODS that are 6 inchs long with a 25 degree angle...mount them with them angled toward each other and they clear the pipes Quote Link to comment Share on other sites More sharing options...
