ellison445 Posted July 11, 2006 Report Share Posted July 11, 2006 Yes it will, a fucked up spark plug will cause backfire which triggers the check engine light to come on. i cleared the code, drove it 70 miles, and just took it to inspection yesterday. It passed Light didnt come back yet so i dont know what it was, all i did was change the spark plugs but that wouldnt cause the error code as far as i know. Quote Link to comment Share on other sites More sharing options...
slowpokebanshee Posted July 18, 2006 Report Share Posted July 18, 2006 I doubt it would cause a back fire with bad plugs, mis-fire yes, backfire, doubtful, and in this day and age of platinum, double platinum, triple platinum, iridium, etc. plugs.....I doubt that was a problem also, plug wires/ignition cables injector etc. would also cause a misfire but that would set a p0300 (p0301,p0302,p0303,p0304,...p0312etc.) we are addressing a low voltage o2 sensor code if I am not mistaken, why did we change plugs? Quote Link to comment Share on other sites More sharing options...
chris642 Posted July 19, 2006 Author Report Share Posted July 19, 2006 (edited) I doubt it would cause a back fire with bad plugs, mis-fire yes, backfire, doubtful, and in this day and age of platinum, double platinum, triple platinum, iridium, etc. plugs.....I doubt that was a problem also, plug wires/ignition cables injector etc. would also cause a misfire but that would set a p0300 (p0301,p0302,p0303,p0304,...p0312etc.) we are addressing a low voltage o2 sensor code if I am not mistaken, why did we change plugs? I changed the plugs becasue it was about time they should be changed, they have been on there for about 50,000 miles and i figured i would just do them now. The old plugs were all white on the tips with some spots of bring yellow on some. Whats this mean? I know on a banshee its not good! Edited July 19, 2006 by chris642 Quote Link to comment Share on other sites More sharing options...
slowpokebanshee Posted August 3, 2006 Report Share Posted August 3, 2006 you add any "snake oil" fuel additives etc. to your fuel, I have had a lot of "odd" colored spots from various brands of fuel additives, cleaners, octane boosters, antifreeze, Fuel injector cleaners etc.I wouldn't worry though Quote Link to comment Share on other sites More sharing options...
