2stroker4ever Posted July 1, 2006 Author Report Share Posted July 1, 2006 There's soooo many different bars, and different bends, on RMATV for example... any suggestions? I'd like to not spend a ton of money just on bars.. like around 50-60 would be good. Something higher, would be nice, your thoughts on a set? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 1, 2006 Report Share Posted July 1, 2006 (edited) Don't forget, you'll need grips too...another 10 to 15 bucks. Get Spyder grips...if RMATV carries them. You will not be dissapointed. Any ATV High or CR High bend bars will be just fine... Magic is usually in the ballpark...and sometimes cheaper than RMATV. Here's a whole bunch to sort through... http://www.magicracing.com/Handlebars_c_155-1.html Edited July 1, 2006 by dajogejr Quote Link to comment Share on other sites More sharing options...
2stroker4ever Posted July 2, 2006 Author Report Share Posted July 2, 2006 I was going through that Magic Racing site to find some of the things I wanted, and I came across this K&N filter, but I'm not sure if I should set the quanity to 1, or 2, or if this is the correct one? http://www.magicracing.com/KN-Filter--Banshee_p_170-454.html I hear people talking about K&N Pod filters, is this what it is? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted July 2, 2006 Report Share Posted July 2, 2006 If your banshee has an airbox, yes...this is what you want. Get an outerwear for it too. If you decide to remove the airbox all together...or it doesn't have one in the first place, then you can get clamp on (or pod) filters that clamp directly onto the back of the carbs. Clamp on or Pod, it's the same thing. If that's the case, Magic has this kit to remove your airbox... http://www.magicracing.com/KN-Clamp-On-Kit...e_p_80-470.html Quote Link to comment Share on other sites More sharing options...
