bansheefire Posted June 25, 2006 Report Share Posted June 25, 2006 how good are these heads and do the make such a big differece i plan on running 22cc domes and have port work and other mods (stock cyl) Quote Link to comment Share on other sites More sharing options...
RILS Posted June 25, 2006 Report Share Posted June 25, 2006 They are good heads.I run one as do many others on here i have no complaints.What is your elevation?You have many choices of domes you can proably go with 21cc and still run pump gas. Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted June 25, 2006 Report Share Posted June 25, 2006 Noss is the best.Cake to install and look sharp. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 25, 2006 Report Share Posted June 25, 2006 Stock CC is 22...so you probably won't notice a perfomance gain, unless it means it's runnign a bit better cause it'll run a bit cooler... 21cc you'll notice a slight bump in compression and little performance gain... Depending on your elevation and compression, you may need to run a mix of race and pump gas or straight race gas if you go smaller than 21cc... And/Or if you start bumping your timing.... Quote Link to comment Share on other sites More sharing options...
watkins Posted June 25, 2006 Report Share Posted June 25, 2006 Great Product, great customer service, great person. Need i say more. Quote Link to comment Share on other sites More sharing options...
MILO Posted June 26, 2006 Report Share Posted June 26, 2006 Great Product, great customer service, great person. Need i say more. i'll second that statement Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted June 26, 2006 Report Share Posted June 26, 2006 talk to pedro at 99 . Have that head milled down a bit , youll acheive somewhat the same results for almost half the cost Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted June 26, 2006 Report Share Posted June 26, 2006 talk to pedro at 99 . Have that head milled down a bit , youll acheive somewhat the same results for almost half the cost go with the noss head you'll be quite satisfied.with the noss if you decide later you wanna make changes you can change the domes.with the noss i feel you get better cooling and besides david's a site sponsor and i'm pretty sure he gives hq members a bit of a discount .great guy to talk and deal with also. Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted June 26, 2006 Report Share Posted June 26, 2006 talk to pedro at 99 . Have that head milled down a bit , youll acheive somewhat the same results for almost half the cost Chase is right, you can save a decent amount of money having the stock head milled, BUT... If you go with a NOSS head like others have said you can change domes as your mods change. Plus, if you look at a disassembled NOSS head, it's no wonder why you get far better cooling than a stock head could ever dream of. I just traded up about a month ago, and I wish I would have done it a year ago! The heads are awesome, you'll get a serious bump on the bottom end. I went with 20cc domes, and I was kicking over 170 psi at 1980' elevation (that means bumping 190 at sea level), and that was with a Snap-On Compression tester (so it's accurate). The only downside to milling or going with an aftermarket head is the possibility of needing race gas. I now run 100% race, but if you've spent a couple thousand plus on extras, what's a few more $/gallon? Do it, and I guarantee you'll be very satisfied. Like others have said, David is a super-nice guy, and there was a decent discount for HQ members on top of everything!! :thumb: Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 26, 2006 Report Share Posted June 26, 2006 Slam a 15cc dome in there and try to kick that thing over a couple times. LOL I run 17's in mine and its a bitch sometimes. Whenever I start it I wish I only had 21cc domes. That would be nice... adjustable domes. Quote Link to comment Share on other sites More sharing options...
strokrbanshee1 Posted June 26, 2006 Report Share Posted June 26, 2006 He is a good guy to deal with.... and good customer service.... Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted June 27, 2006 Report Share Posted June 27, 2006 Slam a 15cc dome in there and try to kick that thing over a couple times. LOL I run 17's in mine and its a bitch sometimes. Whenever I start it I wish I only had 21cc domes. That would be nice... adjustable domes. What's your compression at that elevation though? I would bet at that elevation, plus your porting actual compression psi is probably in the same neighborhood (maybe lower?) as mine. I know mine kicked back at me when I went to try and be nice, not thinking about it one start. That's enough to make you real serious about being firm and decisive when kicking it over! Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted June 27, 2006 Report Share Posted June 27, 2006 What's your compression at that elevation though? I would bet at that elevation, plus your porting actual compression psi is probably in the same neighborhood (maybe lower?) as mine. I know mine kicked back at me when I went to try and be nice, not thinking about it one start. That's enough to make you real serious about being firm and decisive when kicking it over! At this elevation my compression is usually around 152-158psi. Depends on if the weather is really hot or pretty chilly when I test, but its usually around there. Quote Link to comment Share on other sites More sharing options...
Stinger Posted June 27, 2006 Report Share Posted June 27, 2006 At this elevation my compression is usually around 152-158psi. Depends on if the weather is really hot or pretty chilly when I test, but its usually around there. hell man, that's pump gas friendly compression...I had that with 21cc domes before I ported it...now I'm at 155-157 with 20cc domes...+4 timing and 91 octane...runs great. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 27, 2006 Report Share Posted June 27, 2006 (edited) Big Red...can you imagine trying to kick that biyatch at sea level... At about 180 in mine it's a pretty stout kick... Edited June 27, 2006 by dajogejr Quote Link to comment Share on other sites More sharing options...
