parking brake
i belive if you have it disconected you have to have the sensor unplugged . I unplug all the saftey sensors
1 : stock carb tors ( remove the two connectors )
2: Unplug tors box next to spark plug coil
3: unplug the saftey sensor wire that comes out of the throttle housing
4: Unplug the parking break sensor on the clutch lever ? if it has one ?
Cant clearly remember how because i never ran stock. If the parking break sensor is on and u start the bike it should die as soon as u rev it, thats how my old warrior was , and my banshee when i first got it started.
Hope i cleared any information up for you , if you have any questions shoot me a pm and i'll do my best into helping you.
does the parking brake make a difference if it is not on?
verry low rpm rev limmiter takes over so you dont ride w/ P- brake on.
if you disconnect it:
there is a sensor on the lever that the two wires have to be connected together, or if you left linkage on & just removed the cable you can wire up the lever so that it pushes the senser in. It will start & idol but wont rev. above an idol (verry low rpm rev limmiter takes over so you dont ride w/ P- brake on)
