bsrider Posted June 20, 2006 Report Share Posted June 20, 2006 (edited) CAN ANYONE HELP ME? WHEN MY 350 BANSHEE SITS FOR AWHILE I NEED TO SPRAY A FEW SHOTS (VERY SMALL) OF CARB CLEANER OR ETHER DOWN THROTTLE IN ORDER FOR IT TO START. (I'M IN CALIF. SO WEATHER IS NOT A PROBLEM) IT FIRES UP IMMEDIATELY AND STAYS RUNNING. AND I CAN START IT WITH NO PROBLEMS AFTER THAT, AND IT IDLES VERY GOOD. BUT IF IT SITS FOR AN HOUR OR COLD IT WONT START UNLESS I SPRAY. ANY SUGGESTIONS? WILL BE APPRECIATED!! THANKS Edited June 20, 2006 by bsrider Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted June 20, 2006 Report Share Posted June 20, 2006 It could be too lean on the pilot circuit. Try turning in your air mixture screws a 1/2 turn each, and see if that helps. Quote Link to comment Share on other sites More sharing options...
bsrider Posted June 20, 2006 Author Report Share Posted June 20, 2006 It could be too lean on the pilot circuit. Try turning in your air mixture screws a 1/2 turn each, and see if that helps. Thank you for the help! I'll try it and let you know. Quote Link to comment Share on other sites More sharing options...
addicted Posted June 20, 2006 Report Share Posted June 20, 2006 Thank you for the help! I'll try it and let you know. I woder if it good to start a 2 stroke with either? No lubrication on start up. I don't kmow, maybe something to think about. Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted June 20, 2006 Report Share Posted June 20, 2006 swap your carb bowls!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
snowprophet1 Posted June 20, 2006 Report Share Posted June 20, 2006 Check to make sure the short tube that connects the two carbs together is still in place. One carb has a choke, the other doesn't. This tube connects the carbs where the choke area is, so when you pull the choke, both carbs get the extra fuel to start. Somebody I know was tinkering w/the carbs and didn't realize the tube fell off down under the carbs. He was so frustrated he was ready to sell it. I took a look and saw the tube missing. It was laying on top his crankcase just under the carbs. I put it in place and gave it one kick and it fired right up. I should have offered him a couple hundred bucks for it before I looked at it! :yelrotflmao: Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted June 20, 2006 Report Share Posted June 20, 2006 (edited) Check to make sure the short tube that connects the two carbs together is still in place. One carb has a choke, the other doesn't. This tube connects the carbs where the choke area is, so when you pull the choke, both carbs get the extra fuel to start. Somebody I know was tinkering w/the carbs and didn't realize the tube fell off down under the carbs. He was so frustrated he was ready to sell it. I took a look and saw the tube missing. It was laying on top his crankcase just under the carbs. I put it in place and gave it one kick and it fired right up. I should have offered him a couple hundred bucks for it before I looked at it! :yelrotflmao: he says it runs great when warm if the choke tube wasn't there it wouldn't run at all. Edited June 20, 2006 by batoutofshell Quote Link to comment Share on other sites More sharing options...
snowprophet1 Posted June 20, 2006 Report Share Posted June 20, 2006 It was said that it idles good. IF the idle was set real high, it wouldn't pull through the choke circuit as strong, making it harder to start when cold, but if it isn't idling real high, then that's probably not your problem either. Like somebody else stated already, the float bowls are actually different. One has the passage drilled for the "choke" carb, and the other bowl looks identical, but the passage isn't drilled. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 20, 2006 Report Share Posted June 20, 2006 I'd check compression while you're at it...too... Quote Link to comment Share on other sites More sharing options...
