bansheenoobie Posted June 19, 2006 Report Share Posted June 19, 2006 got basically sotck bike other thanvitos superstock pistons t6 pipes dyna ign. with a +10 swinger running gecko dune tires in kinda red clay rich dirt combo where these work pretty good but really dont know what gearing to run. I had a 15 up front and stock in the rear then went to a 17 up front now i only use 1,2,3 in 400 ft but the bike doesnt start to acc. hard until 4 gear so im killing myself just really want some good opinions. Im riding in Va. if that healps any Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted June 20, 2006 Report Share Posted June 20, 2006 got basically sotck bike other thanvitos superstock pistons t6 pipes dyna ign. with a +10 swinger running gecko dune tires in kinda red clay rich dirt combo where these work pretty good but really dont know what gearing to run. I had a 15 up front and stock in the rear then went to a 17 up front now i only use 1,2,3 in 400 ft but the bike doesnt start to acc. hard until 4 gear so im killing myself just really want some good opinions. Im riding in Va. if that healps any if your only running 400 ft , i'd probally run a 15 at the most on the front if your rear is 42.a 14 may also be good. a +10 swinger with the mods you have listed sounds like it's to long.i'd run a +6 at the most if it were me.different pipes would also help,such as fmdf fattys or gnarleys.they are both good low end pipes especially the gnarleys and you can usually pick them up pretty reasonable.just my oppinion Quote Link to comment Share on other sites More sharing options...
banshee#1 Posted June 21, 2006 Report Share Posted June 21, 2006 stick witht the toomeys if u alrady have em dont get fmf's they suck 17 tooth is way high for stock run a 15 up front for ur next upgrade u should port that bitch nd shed move Quote Link to comment Share on other sites More sharing options...
