00ultraz28 Posted June 18, 2006 Report Share Posted June 18, 2006 I'm takin tha banshee for its first run at the track... its an asphault track and i'll have it strapped down with a 16 tooth front sprocket... I also have fmf gold series ,+ 4 timing, intake, and wiseco pistons. I'm just wondering how bad its gonna want to come up in first. Will i be able to pop off the clutch or will I have to do alot of feathering to keep it from standing up bad? Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted June 18, 2006 Report Share Posted June 18, 2006 I'm takin tha banshee for its first run at the track... its an asphault track and i'll have it strapped down with a 16 tooth front sprocket... I also have fmf gold series ,+ 4 timing, intake, and wiseco pistons. I'm just wondering how bad its gonna want to come up in first. Will i be able to pop off the clutch or will I have to do alot of feathering to keep it from standing up bad? i think you'll have to feather the clutch starting out .you have a 16 on front ,what about the rear?what is the length of the track you plan on running?you might do decent in the eigth mile but in the quarter you'll be geared to low. Quote Link to comment Share on other sites More sharing options...
00ultraz28 Posted June 18, 2006 Author Report Share Posted June 18, 2006 its a quarter track and i have the stock tooth out back... what gearing would i need to run the full quarter without running out of gear Quote Link to comment Share on other sites More sharing options...
00ultraz28 Posted June 19, 2006 Author Report Share Posted June 19, 2006 I've been hearing now i should leave in 2nd on the gas and just pop off the clutch. I guess I'll just have to try both approaches and see what works the best Quote Link to comment Share on other sites More sharing options...
banshee332 Posted June 19, 2006 Report Share Posted June 19, 2006 I've been hearing now i should leave in 2nd on the gas and just pop off the clutch. I guess I'll just have to try both approaches and see what works the best since im guessing you still have the stock axle. for the 1/4 mile you should run 19-37 or 18-37. Thats just my 02 Quote Link to comment Share on other sites More sharing options...
wesw Posted June 22, 2006 Report Share Posted June 22, 2006 I've been hearing now i should leave in 2nd on the gas and just pop off the clutch. I guess I'll just have to try both approaches and see what works the best it would be very hard to gear your bike to leave in sec gear to run 1/4 race. your going to have to run like a 16-39 and start in first and hope your better than me cause my bike grabs neutral every time while speed shifting into sec. thats would be my advice. Quote Link to comment Share on other sites More sharing options...
scuba147 Posted June 22, 2006 Report Share Posted June 22, 2006 I start out in first gear on pavement-dump the clutch and sit as close as possible to the tank. Do it a few times and you will get use to it. Quote Link to comment Share on other sites More sharing options...
00ultraz28 Posted June 22, 2006 Author Report Share Posted June 22, 2006 Yeah I think the guy that was telling me I could start in second was full of himself.... I'm just gonna have to strap the front down and play with it a few times before I go to the track friday. Right now i'm not really too concerned with how it does as far as being geared to run a full quarter. I'll worry about that when i get another one to ride and turn this one into a full drag bike Quote Link to comment Share on other sites More sharing options...
snowprophet1 Posted June 22, 2006 Report Share Posted June 22, 2006 I put a set of yamaha srx snowmobile shocks on the front of mine, and chained them down lower yet. I used an R6 crotch rocket rear shock (slight modifications) for a nice low and effective suspension for dirt drags/asphault. I have a 16 tooth front and stock rear sprocket for the 1/4 mile, but I am running 22" holeshots. Tire size will make a big difference in gearing. I am laying on the front, wide open holeshots in first gear. Very addictive!!! Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted June 22, 2006 Report Share Posted June 22, 2006 Yeah I think the guy that was telling me I could start in second was full of himself.... I'm just gonna have to strap the front down and play with it a few times before I go to the track friday. Right now i'm not really too concerned with how it does as far as being geared to run a full quarter. I'll worry about that when i get another one to ride and turn this one into a full drag bike You're gonna be out of gear at half track and it's gonna suck, LOL. 1/8th mile you might be alright like blueshee said, but you're gonna have to run something around an 18/38 gearing to make your passes worthwhile in the 1/4....and you'll be needing every one of those 6 gears :shrug: You could just let off after the 1/8 mile mark and see what you turn there....I really think you'd be wasting your time running the quarter with 16/41 gearing Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 22, 2006 Report Share Posted June 22, 2006 unless you have some pretty serious motor work you arent pulling an 18 or 19 tooth sprocket... Quote Link to comment Share on other sites More sharing options...
badcompany Posted June 25, 2006 Report Share Posted June 25, 2006 unless you have some pretty serious motor work you arent pulling an 18 or 19 tooth sprocket... Aint that the truth. You dont need as much gear as u think to run the 1/4, it just takes some testing. I run a drag gas 350 and had trouble pulling a 17/39 through the 1/4, i was only pulling mid to high 90 mph, and i pulled 99 mph with 15/39. THe difference was, with the 17, i wasnt near topped out yet, and with the 15, i was topped out 20 feet passed the 1/8. Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted June 26, 2006 Report Share Posted June 26, 2006 unless you have some pretty serious motor work you arent pulling an 18 or 19 tooth sprocket... my 10 mill pulls a 17/38 yet i have never had her at the track yet , only neighborhoods Quote Link to comment Share on other sites More sharing options...
