kman96 Posted June 18, 2006 Report Share Posted June 18, 2006 hey i was wandering if somebody could tell me what the 2+2 on the durablue eliminator axle means. is it that the axle is 2 inches wider than stock with an option to make it 2 more inches wider? also, is this the axle i would want if i was going to run +2+1 a arms. thanks guys, i am new to all this and currently rebuilding my banshee from the ground up. Quote Link to comment Share on other sites More sharing options...
Dmcbanshee Posted June 18, 2006 Report Share Posted June 18, 2006 +2+2 are +2 inches each side of axle then +4 inches more than a stock.And if you have +2+1 a-arms like you said this axle are good for you I run the same setup and I like it Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted June 19, 2006 Report Share Posted June 19, 2006 +2+2 are +2 inches each side of axle then +4 inches more than a stock.And if you have +2+1 a-arms like you said this axle are good for you I run the same setup and I like it what does the +2+1 ( A-arms) mean? Quote Link to comment Share on other sites More sharing options...
wesw Posted June 19, 2006 Report Share Posted June 19, 2006 2 inchs wider 1 inch forward Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted June 19, 2006 Report Share Posted June 19, 2006 (edited) 2 inchs wider 1 inch forward :baseball_mitt: thanx. 2" per side or total & what is the benefit for "-" , "+", forward besides length caster ? Edited June 19, 2006 by 275hp banshee's Quote Link to comment Share on other sites More sharing options...
