broke Posted June 18, 2006 Report Share Posted June 18, 2006 Can the spacers at the frame mounts be moved to the other side? The A-arms hit the pipes at full compression, but if moved to the other side they will clear. Quote Link to comment Share on other sites More sharing options...
JKJK Posted June 18, 2006 Report Share Posted June 18, 2006 I would give it a try.As long as you move the lower ones too.The geometry should stay the same,just increases the wheelbase a little.You should only have to adjust your tierods to keep the set up the same.Assuming the shocks+or tierods don't create new issues with the a-arms.Good luck,i hope it works out for ya.That's a very impressive ride you have there! Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted June 18, 2006 Report Share Posted June 18, 2006 I dont see why you couldnt do it but i dont know if you shock mounts would line up which causes problems. :baseball_wacko: Quote Link to comment Share on other sites More sharing options...
brock_fuzzy_69 Posted June 18, 2006 Report Share Posted June 18, 2006 only drawbacks that i can think of is possibly more bumpsteer from the steering stem to spindle being at a slight angle Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted June 18, 2006 Report Share Posted June 18, 2006 (edited) What about cutting the spacer in half and putting it in the middle. Maybe it wouldnt hit the pipes then. :baseball_wassat: Edited June 18, 2006 by EastCoast Banshee Quote Link to comment Share on other sites More sharing options...
broke Posted June 18, 2006 Author Report Share Posted June 18, 2006 Thanks guys, I didn't think it was going to be an issue. Moving them barely if any changes the shock angle which has pretty compliant joints to start with. The long travel front end hits at the last 1 1/2". A standard travel front end would have been a cake walk. I can actually adjust the Heims to get the spindle back into the same exact spot, but that will be plan B. Quote Link to comment Share on other sites More sharing options...
willow2679 Posted June 19, 2006 Report Share Posted June 19, 2006 (edited) i put it on the picture forum too if you change the spacers you change the caster they are for that but your quad is going to handle different in the lonestar page is one page that is like a tutorial of how to do the changes and what they mean btw now that I see you have upper a-arms with heim joints, you can change the spacers but you have to play with the heims to have the same caster settings setting and maybe clear the pipes but before any adjustment try to find how to do it good and what the changes mean (maybe calling lonestar to have advice) I think you can Edited June 19, 2006 by willow2679 Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted June 19, 2006 Report Share Posted June 19, 2006 you could cut and re-weld the rear tab of the shock mount on the arm and move the upper and lower arms foreward. You wouldnt have any castor troubles then. I think a few companies make 0 to +1 adjustable arms that are very similar to what you have, except they have spacers on the shock mount too. Quote Link to comment Share on other sites More sharing options...
