dashee03 Posted June 16, 2006 Report Share Posted June 16, 2006 Will you see more performance gains from ported stock reed cages or aftermarket reeds like vforce3? Quote Link to comment Share on other sites More sharing options...
woodro77 Posted June 16, 2006 Report Share Posted June 16, 2006 do a search on this topic Quote Link to comment Share on other sites More sharing options...
jankab Posted June 16, 2006 Report Share Posted June 16, 2006 Will you see more performance gains from ported stock reed cages or aftermarket reeds like vforce3? V 3 will out perform by a mile Quote Link to comment Share on other sites More sharing options...
rtracy Posted June 17, 2006 Report Share Posted June 17, 2006 Will you see more performance gains from ported stock reed cages or aftermarket reeds like vforce3? $250.00 is alot of money. Your stock reeds are capable of flowing well enough. I think vforce would slow the flow down over stock makeing them better for low to mid range. Quote Link to comment Share on other sites More sharing options...
00ultraz28 Posted June 17, 2006 Report Share Posted June 17, 2006 so how do i get my stock reeds to flow WELL ENOUGH... i'm all for adding power without spending money Quote Link to comment Share on other sites More sharing options...
njbanshee Posted June 19, 2006 Report Share Posted June 19, 2006 Go with v force. You will love them. One of the best improvements i've made on my bike. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted June 19, 2006 Report Share Posted June 19, 2006 If stock reeds out-performed aftermarket reeds then they wouldn't be selling them very long. Plus everyone would be doing that mod instead of replacing them. Bottom line is "IF" money is an issue then have the stockers modified, but they will not out-perform V-3's or any other ones. They are designed to perform, and the stock ones are designed to "work", and they perform a bit, but not as good as the aftermarket ones. :beer: Quote Link to comment Share on other sites More sharing options...
Buttermilk421 Posted June 19, 2006 Report Share Posted June 19, 2006 I've got the V2's on one bike and stock ported cages with carbon fiber reeds set up with high tension on another Banshee. VForce gives more power and better throttle response, plus a broader power spread. It's all about how much money do you want to spend for the amount of HP your after. My race quad gets the $$$ for the HP, while the play quad gets what 'works' (value vs. hp gained). Quote Link to comment Share on other sites More sharing options...
