how should i jet it?
sj30
I got a '00 shee with the t5 toomey exhaust and a k&n air filter, everything else is stock and I was thinking about taking my air box cover off but wondered if it would need to be re-jetted. This is my first atv that I've tried to do mods to so I wasn't quite sure what to do.
with those mods you will have to rejet. Depending on elevation i would suggest a 300 main jet and just start from there. I had the samr mods a while back with the lid and Im 300ft. above sea level I was using a 280 main jet. :thumb:
dashee is right on.
However...keep in mind if you take off the air lid, you need the adapter that will hold the filter to the front of the airbox. The lid acutally helps seal the filter.
It's called a proFlow adapter...I THINK they're around 30 or 40 bucks...not 100% sure though.
You HAVE to have this if you remove the lid...
Or...you could just cut a few holes in the lid.
LId off...300 and work your way down. Lid on, 280 and work your way down. stock pilots will be fine.
This is for sea level to 1000ft...by the way...you didn't mention your elevation or temps...
