one carb running out when pinned..
Or for half the price, a fuel pump...it'll flow enough for just about everything...
Or...the old trick of removing one of the floats. That gives you that much more space for gas...
Or...larger float bowls...
Make sure your fuel lines are clear and unkinked, too...
Question...CD...
How long does it take them to run out of fuel?
I'll be running a similar setup, soon... Normally, our longest drags are anywhere from 500 feet to around an 1/8 mile...
I've been told and read...unless you run alky and a drag port...a stock should flow enough..
Whaddaya think?
the one side that's running out might need your float height adjusted.....it could be set where it's NOT allowing the max amount of fuel in your bowl, therefore, sucking it dry too soon.....this is a very good possibility to fix your problem....
I would pull onto the pavement form the dirt and when i would get to 5th gear and start to top out it would sputter and if i didn't let off it would cut out completely, thats with a 16/41 gearing so probably a little sooner with a 15t or less front due to the faster revs. It was mt right carb that was running out to and i don't know why, i adjusted the float heights a little higher than specs to see if a little more fuel in the bowl would help but same problem so i bought the pingel and problem solved. Its easy to install. Take the old gas valve out of the tank and take a knife and cut the middle of the two hole out and make it a little wider. The directions come with the pingel valve and they are very descriptive.
