IamKazam Posted June 7, 2006 Report Share Posted June 7, 2006 Would a single 38mm cv carb kit work well with a 421 cub. I know that cubs are top end motors but, I just think that one carb would be easier to tune than 2 plus you dont have to worry about carb sync. Quote Link to comment Share on other sites More sharing options...
EastCoast Banshee Posted June 7, 2006 Report Share Posted June 7, 2006 (edited) No sense in owning a cub if you dont let it breath. Get yourself two carbs, 34s should do fine Edited June 7, 2006 by EastCoast Banshee Quote Link to comment Share on other sites More sharing options...
bansheeseat$$ Posted June 7, 2006 Report Share Posted June 7, 2006 Would a single 38mm cv carb kit work well with a 421 cub. I know that cubs are top end motors but, I just think that one carb would be easier to tune than 2 plus you dont have to worry about carb sync. My 06 shee has the single 38mm setup and I shread other cubs with two 35mm carbs.My .02 cents Quote Link to comment Share on other sites More sharing options...
IamKazam Posted June 7, 2006 Author Report Share Posted June 7, 2006 Thats what I was thinking. Does it help out with bottom end? Quote Link to comment Share on other sites More sharing options...
bansheeseat$$ Posted June 7, 2006 Report Share Posted June 7, 2006 Thats what I was thinking. Does it help out with bottom end? Honestly I don't know about the added bottom end.When I built this cub engine the 38mm setup is what I put on it and I haven't ever put a dual set up on this engine.I know in my case when I start off it seems ok at the bottom but if I slip the clutch and pin it at a slow cruising speed it pulls instantly. Quote Link to comment Share on other sites More sharing options...
jay shafer Posted June 8, 2006 Report Share Posted June 8, 2006 Isn't it a 41 single made also? I think Cascade was telling me that its one that big for the single carb kit. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted June 8, 2006 Report Share Posted June 8, 2006 Cascade carries 2 one into two carb setups. If you look on their site, under Cubs, they have the 38 in standard and polished variety... Aww...hell, I'm bored at work, here ya go. Funny...I don't see it on their site now. I'm 100% positive it was there before, and for over 410cc cubs, they recommend a 38PWK...here's the little brother... http://webforce.nwrain.net/founder/cascade...TORE_DEPT_ID=87 Quote Link to comment Share on other sites More sharing options...
jay shafer Posted June 8, 2006 Report Share Posted June 8, 2006 That is where i seen it at too, but now its not there. I had called he said something about a 41 also but never seen it on his site. Quote Link to comment Share on other sites More sharing options...
